Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By snowyweston
Thread: Wrong schedule formula calculation
  1.    #1
    January 19, 2017
    11
    08:41 PM
    Hello
    I'm trying to calculate something with a Revit schedule, but the calculated value i wrong?
    I've made to parameters called "GWP (MIP_K)" and "R_MIP - GWP".
    GWP (MIP_K) = 4,88
    R_MIP - GWP = 9,38
    And then I made the formula: GWP (MIP_K) / R_MIP - GWP
    But it's wrongly calculated to 1,47 and not 0,52 as it should be.
    If I use a "+" and not "/", its works perfectly fine, but I need to divide it.
    this formula: GWP (MIP_K) + R_MIP - GWP = *14,26‬ is correct??
    Can anybody tell me what migth be wrong?
  2.    #2
    December 21, 2010
    C.LONDON
    4,374
    07:41 PM
    Quote Originally Posted by Krogstrup View Post
    Wild guess, you've other parameters MIP_K and GWP elsewhere - and Revit is confusing them in your calculation because you have mathematical annotation in your parameter names, specifically:
    GWP (MIP_K)
    R_MIP - GWP
    you really don't want that stuff anywhere near numeric parameter names if you're ever going to do anything with formulas with their values.
  3.    #3
    January 19, 2017
    11
    08:41 PM
    I'd tried to change all the names from "-" to "_" and removed all parenthesis, but nothing has changed in the calculated value.
  4.    #4
    December 21, 2010
    C.LONDON
    4,374
    07:41 PM
    What are unit types of each parameter, and the unit type of the calculated value?
    (Screenshots help things immeasurably)
  5.    #5
    Moderator DaveP's Avatar
    January 10, 2011
    St Paul, MN
    2,960
    01:41 PM
    I agree with Snowy. Not a good idea to use special characters in your parameter names.
    Even if it doesn't stuff up the calculation, it makes them hard to read & somewhat ambiguous.
    I'm not a big fan of spaces, either. BetterToUseCamelCase.
    If you absolutely MUST have () or - or * in your parameters, you'll have to surround the parameter with square brackets:
    [GWP (MIP_K)] / [R_MIP - GWP]
    And now that I look at that again, I thought your original formula divided GWP (MIP_K) by R_MIP and then subtracted GWP
  6.    #6
    January 19, 2017
    11
    08:41 PM
    I think I found the reason to my problem, but I can't seem to solve it.
    The schedule was unsorted and the numbers show where the total. I thought that this was fine, but it do not calculate the total values.
    Altso I changed a lot of the names and added the parameters to the formula. So now it's the "MIP_B"-group divided with "R_MIP"-group, which should equals X_GWP
    Schedule:
    Formula:
    When I sort the schedule I can see there the calculation error is. It calculates each category and do not use the totals. Is there any way to solve this problem?
    Sorted schedule:
  7.    #7
    December 21, 2010
    C.LONDON
    4,374
    07:41 PM
    As you have discovered - calculated fields (in Revit schedules) do not, without some considerable hackery, do not consider in-line/row/column totals.
    Search out Ekkonap's posts on the method (I think in the "formulas for everyday use" thread)
    Krogstrup likes this.
  1. Duct connector causing formula to allow wrong answer?
    By jturovskiy in forum MEP - Family Creation
    Last Post: April 17th, 2019, 11:14 AM
  2. Unexpected Value Rounding with a Calculation Formula
    By cellophane in forum Architecture - Family Creation
    Last Post: October 24th, 2018, 08:52 PM
  3. Area calculation wrong - Schedules
    By MARIA1993 in forum Architecture and General Revit Questions
    Last Post: March 22nd, 2018, 02:31 PM
  4. Help!!!!!!! with Calculation Value in a schedule
    By roadiedesigns in forum MEP - General
    Last Post: July 28th, 2013, 02:19 AM
  5. Schedule formula (is there a formula expert in the house?)
    By John McCamont in forum Architecture and General Revit Questions
    Last Post: September 9th, 2011, 09:50 PM
Tags for this Thread
