Results 1 to 5 of 5
Thread: Revit Topograpghy
    July 26, 2018
    17
    06:36 AM
    Revit Topograpghy
    Hi there,
    I'm working on a contoured riverfront but when I made the contours in revit something is not right. I can't get the right rise in site. The contours are 15' high. I don't know if I did something wrong or it's suppose to be like that. I'm attaching the screen shots and file below. Help me!!
    Thank you in advance
    Attached Thumbnails Attached Thumbnails Revit Topograpghy-1.png   Revit Topograpghy-untitled.png
    Attached Files Attached Files
    July 26, 2018
    17
    06:36 AM
    Correct unit of measurements means? I used Feet fractional to inches in both at least that's what I think I did
    Senior Member kamranmirza's Avatar
    January 12, 2011
    London, UK
    535
    02:36 AM
    Hi alycealvi,
    I think you've got to understand what you've got as a topography: the lowest point is ~15'-0" and the highest point is ~75'-0".
    BUT your topo is about ~51,500'-0" across, which is nearly 9.75 MILES !!!
    So it will look like that. The height to width ratio will be ~75' / 51,500' = ~ 0.00146
    January 12, 2011
    London, UK
    535
    02:36 AM
    As far as seeing contours at 15'-0" intervals, have a look at this site:
    https://knowledge.autodesk.com/suppo...40A4C-htm.html
    And you hadn't set the contour interval correctly, it was set @ 3'-XX" or something. This is what it will look like @ 15'-0":
    Best of luck with your project !
    Coeur d Alene, ID
    4,779
    06:36 PM
    Also...don't trust your contour data in the dwg to create the topo from layers...the lines are not at the same height.
  1. Building pad doesn't cut topograpghy
    By constrainmenot in forum Architecture and General Revit Questions
    Last Post: January 1st, 2015, 10:30 PM
