Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Like Tree12Likes
Thread: Angular Facade Geometry
  1. #11
    September 11, 2013
    70
    09:58 PM
    GMs are just as schedulable. And Revit categories mean nothing outside of Revit.
    Ok, I get that, but it does seem quite a 'dirty' way of using the software.
    I like the idea of making the 'column' sections GMs and hosting them in with a normal curtain system though
  2. #12
    December 21, 2010
    Phoenix, AZ
    2,628
    01:58 PM
    Its not. Its smart.
  3. #13
    Member Bjorn_K's Avatar
    April 8, 2011
    Rotterdam, Netherlands
    324
    10:58 PM
    Preach Greg, preach!
  4. #14
    December 21, 2010
    C.LONDON
    4,392
    09:58 PM
    Quote Originally Posted by GMcDowellJr View Post
    Its not.
    /PantoModeOn
    Oh yes it is.
    /PantoModeOff
    All the best things are dirty.
    Grumple likes this.
  5. #15
    July 7, 2011
    Rotterdam, Holland
    1,250
    10:58 PM
    *Robin, Q. are your pieces individually placed/stacked/aligned elements?
    Yes they are. Interesting bit is that in the entire building there are just 4 different pieces of concrete, including the corners.
    snowyweston and cellophane like this.
  6. #16
    December 21, 2010
    C.LONDON
    4,392
    09:58 PM
    Quote Originally Posted by Robin Deurloo View Post
    Now that's Design Management
    In my screenshot alone I count a minimum of 24 distinct pieces, and that's but one section from a four-order tower, itself one type of four, on a single phase of a project.
  7. #17
    September 11, 2013
    70
    09:58 PM
    Doesn't that mean you have hundreds of floating generic models that can just be moved freely in any direction?
    This just doesn't seem workable in a standard practice, where you have multiple people of very different skill levels working on a model. One accidental nudge on one of the hundreds of GMs (with no warning messages) and your drawings are screwed...
    We've decided to make the facade 'framing' elements GMs and use curtain walling between this frame. This should allow us to create the required shapes for the frame (joining at corners etc...) and keep the curtain wall elements fairly simple for people to work with.
    Thanks for all the input, it's been interesting to see how you guys work!
  8. #18
    July 7, 2011
    Rotterdam, Holland
    1,250
    10:58 PM
    Quote Originally Posted by Grumple View Post
    Group and pin ?
  1. How do I make this angular junction
    By viratmanchanda in forum MEP - General
    Last Post: December 24th, 2015, 06:48 PM
  2. Angular Parametrics
    By doni49 in forum Architecture - Family Creation
    Last Post: August 10th, 2015, 05:42 AM
  3. Angular Facade, how would you go about it?
    By nPoika in forum Architecture and General Revit Questions
    Last Post: March 27th, 2014, 12:41 AM
  4. Dimension - Angular
    By Joshua Kohl in forum Architecture and General Revit Questions
    Last Post: October 29th, 2013, 04:02 PM
  5. Inputting Angular Dimensions
    Last Post: November 26th, 2012, 05:02 PM
