Page 1 of 2 12 LastLast
Results 1 to 10 of 13
Like Tree9Likes
Thread: Semi-Rigid Hatch
    March 26, 2019
    9
    01:21 PM
    Semi-Rigid Hatch
    Does anyone know where I can find a .pat file for semi-rigid insulation that looks more like the standard CAD insulation (ie like the attached pic)? I've tried making my own hatch patterns in the past with limited success (I have trouble wrapping my brain around the syntax and visualizing the end result). If anyone knows of a ready made file I'd be eternally grateful.
    Attached Thumbnails Attached Thumbnails Semi-Rigid Hatch-semi-rigid-insul.jpg
    Coeur d Alene, ID
    4,801
    10:21 AM
    Download Pyrevit...draw out the lines in a drafting view or plan view...run the fill pattern tool. Make your own without having to figure out angles, offsets, and dashes, etc...
    willsud likes this.
    10,277
    12:21 PM
    Fyi- a specifically boundaried pattern like that (dependant on lines starting on both ends) is going to be a PITA in Revit, as you might need a bunch of different hatches for different thicknesses of materials. AND you need them all set to orient to object, or it will be wrong.
    I would bite the bullet and switch to a more generic hatch pattern.
    GMcDowellJr and d.stairmand like this.
    Coeur d Alene, ID
    4,801
    10:21 AM
    To add to Aaron's comment....if you do use that pattern and it is a set size. I would suggest using it in a linebased detail item so you can lock the fill pattern to the specific size and not use it for material cut patterns. I've done the same thing with a plywood cut that is liked from the CAD days.
    February 23, 2018
    Port Elizabeth, South Africa
    72
    05:21 PM
    Why not just use a line based family and array those lines without a fill pattern?Semi-Rigid Hatch-line-family.jpgSemi-Rigid Hatch-lines1.jpg
    10,277
    12:21 PM
    Because then you are basically saying in EVERY section and detail the model will get completely drafted over, since there isn't a good enough cut pattern to let the modeled object stand on its own. Which is crazy.
    sdbrownaia likes this.
    July 10, 2015
    Boise, Idaho
    678
    11:21 AM
    I just use a simple cross hatch pattern because the guy in the field doesn't know the difference or care. In the end the hatch pattern doesn't determine if it gets built. We're lucky if any similarity between what's drawn and built is more than coincidence.
    May 18, 2011
    Calgary, AB
    402
    11:21 AM
    Quote Originally Posted by DavidLarson View Post
    Second that. I got better things to do (coordinating consultants) than redraft components to make it look like we use to in CAD.
    But to answer OP's question, we do have a line based detail component with an array of lines.
    February 23, 2018
    72
    05:21 PM
    OK, fair point. However, Revit has a detail item for insulation which is the same thing, so it's an alternative for that.
    Coeur d Alene, ID
    4,801
    10:21 AM
    Quote Originally Posted by Tim123 View Post
    But the insulation tool is just "adding" more detail vs "covering up". Something I try to do with all my detail items, such as CMU joints vs entire CMU blocks that just cover up the wall material. Of course then I had that LB detail item that was funky...built it and nobody uses it..
  1. Hatch in Family not matching wall hatch
    By krystal211 in forum Architecture - Family Creation
    Last Post: May 7th, 2018, 08:07 PM
  2. Rigid Slab & Foundation Insulation
    Last Post: August 13th, 2015, 02:13 PM
  3. Semi-transparent elevations
    By ErlingPerling in forum Architecture and General Revit Questions
    Last Post: June 16th, 2015, 03:02 PM
  4. Semi-Multi-discipline
    By Gabriel Black in forum MEP - General
    Last Post: July 5th, 2011, 09:14 AM
