Results 1 to 3 of 3
Like Tree1Likes
  • 1 Post By sdbrownaia
Thread: Column and Wall Connection with Wrap Problem
    March 27, 2017
    3
    12:09 AM
    Hi, I have a problem at connection point of wall and column. The wall's setting is set to "wrap at wall ends". But when connected to column it should not wrap. İf anyone has an answer I would appreciate a lot. Thank you.
    December 20, 2010
    1,077
    08:09 PM
    Unfortunately end wraps is not an instance parameter so you would need to split your wall and make a duplicate wall type with no wraps for the side touching the column.
    mchvll likes this.
    March 27, 2017
    3
    12:09 AM
    Quote Originally Posted by sdbrownaia View Post
    Got it thank you.
  1. Problem drawing Beam,Column connection
    By eng ebrahim in forum Structure - General Questions
    Last Post: February 6th, 2019, 07:41 PM
  2. Wall - Column - Ceiling Problem
    By Wobbuffet in forum Structure - General Questions
    Last Post: December 23rd, 2016, 06:19 PM
  3. Wall wrap problem
    By atis in forum Architecture and General Revit Questions
    Last Post: August 2nd, 2015, 11:40 AM
  4. Revit Extensions placing column base connection at top of column
    By wardley31 in forum Architecture and General Revit Questions
    Last Post: December 4th, 2014, 10:29 AM
  5. Arch wall Connection with structural column
    By smith125 in forum Architecture and General Revit Questions
    Last Post: December 4th, 2014, 08:39 AM
Tags for this Thread
