Results 1 to 2 of 2
Thread: Area Tags
    January 18, 2017
    Eden Prairie, MN
    76
    03:47 AM
    Area Tags
    We have an area plan of a multitenant building with the actual areas listed. In the area schedule, we have a column for Rentable Area. It there a way in which the Rentable area from the schedule can appear in the area plan instead of the actual area? In other words, can the rentable number from the schedule be linked to the area plan so when the rentable number changes in the schedule, the number on the plan will also change?
    December 20, 2010
    1,058
    04:47 AM
    Revit has multiple "Area Schemes" one for example is gross and meant to create area plans and schedules reporting the gross building areas, then you can make additional schemes, one built in is for rentable. This is the one you are looking for, you place the boundaries where you want to give the rentable areas you wish to show.
  1. Area Schedule - change Area Type
    By anthonyB in forum Architecture and General Revit Questions
    Last Post: December 6th, 2017, 03:34 AM
  2. Room Tags & Area Plans
    By Karstileigh in forum Architecture and General Revit Questions
    Last Post: April 11th, 2013, 03:02 PM
  3. Second number as calculated in area tags
    By JTB in forum Architecture - Family Creation
    Last Post: January 11th, 2013, 05:36 AM
  4. Default Position of Door Tags (or any tags for that matter):
    By Jj Mac in forum Architecture and General Revit Questions
    Last Post: December 23rd, 2011, 08:45 PM
  5. Area Tags
    By redmonki in forum Architecture and General Revit Questions
    Last Post: October 10th, 2011, 06:47 AM
