Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Like Tree7Likes
Thread: Survey and Base point
    December 4, 2018
    9
    02:45 AM
    Hi all,
    Can someone explain to me in real project terms how these 2 points should be used?
    From my understanding, which could be wrong, is that;
    Base point is a shared point of a building that is used as a reference? Is this also used in elevation to set the height of the model to a real world height?
    Survey point is a real world coordinate used when sharing models for coordination?
    Does anyone have any links that may be useful in understanding these.
    Sorry for the vagueness but for some reason I cant get my head around these.
    Thanks
    November 18, 2016
    93
    02:45 AM
    that's pretty much it. i found this site informative about it all
    https://revitpure.com/blog/13-tips-t...rdinate-system
    RevitUser83 likes this.
    October 16, 2015
    2
    01:45 AM
    December 4, 2018
    9
    02:45 AM
    Thanks both, very helpful
    September 25, 2014
    17
    09:45 PM
    Quote Originally Posted by robp View Post
    What do you think about this part? I generally like that post/pamphlet but I don't understand the point of the offset.
    5- SET LEVELS RELATIVE TO PROJECT BASE POINT
    In most projects, it is a smart move to set the project first level at 100'-0'' or 10,000mm. This is an arbitrary value that has no relation to the sea level. The best practice is to set this value in relation to the Project Base Point. Select a level, click on Edit Type and make sure that the Elevation Base is set to Project Base Point.
    These four posts from Steve Stafford are comprehensive and a great resource:
    2015 Survey Point - Post 4 - Acquiring Coordinates and View Orientation
    2015 Survey Point - Post 3 - Five Minutes with Shared Coordinates
    2015 Survey Point - Post 2
    2015 Survey Point 1
    Moderator DaveP's Avatar
    January 10, 2011
    St Paul, MN
    2,980
    08:45 PM
    We set our First Level to 100'-0" because we have levels below that. Foundation, Basement, Parking.
    We don't want anything below grade to have a negative number.
    bryangrzonka likes this.
    December 21, 2010
    Phoenix, AZ
    2,599
    06:45 PM
    I worked with a young architect once who lost their mind when I did this in a project... they’d never seen it before and assumed it was wrong. :shrug:
    Coeur d Alene, ID
    4,779
    06:45 PM
    While my template has Level 1 at 0'...this can be changed accordingly if using actual heights. I also keep a Site Level at 0' which should never be changed and which the topography is created from. Of course then users need to change Level 1's height. I had some users that did not like the Site Model and Project Model process.
    10,175
    08:45 PM
    Quote Originally Posted by GMcDowellJr View Post
    I wouldn't lose my mind over it, but its an opinion matter: If someone asked me, i would tell them "i thought it was wrong," too. Ive heard all the reasons for it, and i hate them all, and find them to be nonsensical. L1 is 0-0 for me.
    December 21, 2010
    Phoenix, AZ
    2,599
    06:45 PM
    Frankly, if it was my company, I'd use the survey elevations with dimensions between them in section in case you were bad at math.
  1. Elevation to Survey Point or Project Base Point?
    By robp in forum Architecture and General Revit Questions
    Last Post: January 7th, 2019, 02:59 PM
  2. Adjust project base point vs survey point in elevation
    By iru69 in forum Architecture and General Revit Questions
    Last Post: March 13th, 2018, 04:56 PM
  3. Project Base Point and Survey Point are both 0.00 elevation, but different heights
    By PatrickGSR94 in forum Architecture and General Revit Questions
    Last Post: March 5th, 2018, 02:13 PM
  4. Survey Point in Gauß Krüger coordinate system - project base point (0,0,0)
    By LisaTUWien in forum Structure - General Questions
    Last Post: December 18th, 2017, 03:04 PM
  5. Project Base Point | Survey Point | Absolute Elevation Issue
    By siqbal16 in forum Structure - General Questions
    Last Post: March 29th, 2016, 10:16 PM
