Results 1 to 3 of 3
Thread: staircase doesn't show like they should
    February 10, 2018
    1
    11:54 PM
    Question staircase doesn't show like they should
    I've a problem that I couldn't resolve yet. look at the floor plan that I provided in the post (you can see it also at the 3d pic). in the floor plan the 2 staircase looks strange (one over one) how can I fix that?
    Attached Thumbnails Attached Thumbnails staircase doesn't show like they should-58373216_10157321244598970_891102398481694720_o.jpg   staircase doesn't show like they should-58430393_10157321244618970_2502742756946870272_o.jpg   staircase doesn't show like they should-58008111_10157321244778970_8013221325684342784_n.jpg
    Coeur d Alene, ID
    4,744
    01:54 PM
    Is the view using wireframe vs hidden?
  3.    #3
    December 8, 2010
    Long Beach, CA
    201
    01:54 PM
    Looks to me like it is in Hidden Line mode. It's the overhead runs showing as dashed. This is the part about stair modeling (documentation) i detest. Have not yet found a workflow i love, even after working in Revit for many years.
    For me, it's playing the dumb linework game when dealing with overlapping up/down runs. Plan regions, view range, etc doesn't get it done. I wish i knew of better options. For starters, i'd probably suppress the overhead riser line subcat in the example above since it doesn't add much to telling the story....one less line to battle with. Keep the overhead nosing lines on, possibly suppress those as well? For the latter, it would depend on how it is being documented. That might help to clean up the dwg, IMHO.
    Jon
  1. Tick Marks On Wire Doesn't Show
    By awinston in forum MEP - General
    Last Post: April 29th, 2016, 05:33 PM
  2. K Series Joist Doesn't show up in Schedule
    By alexo4141 in forum Structure - General Questions
    Last Post: May 16th, 2015, 12:09 AM
  3. Imported AutoCAD file doesn't show up?
    By Lox in forum Architecture and General Revit Questions
    Last Post: June 10th, 2013, 04:47 PM
  4. Wall Detail doesn't show
    By Ant123 in forum Architecture and General Revit Questions
    Last Post: May 14th, 2013, 12:46 PM
  5. my 3D view doesn't show the hole image anymore??!!!!
    By sixingno1 in forum Architecture and General Revit Questions
    Last Post: November 30th, 2011, 07:46 AM
