Results 1 to 1 of 1
Thread: Sloped glazed panel- issue with shed roof
    November 2, 2017
    1
    11:41 AM
    I'm attempting to model a standing seam metal shed roof with a sloped glazed panel. My process was.....create roof using standard wood rafter roof, copy and align in same place, select copied roof, change properties to sloped glazed panel then move above the standard roof. It went smoothly except the "moving above standard roof" part. I attempted same process with flat roof & hip roof and had no problems.
    What am I missing with the shed roof? I've attached the file.
    Attached Files Attached Files
  1. L-Shaped Shed roof - Revit
    By malou_denum in forum Architecture and General Revit Questions
    Last Post: May 18th, 2016, 05:27 AM
  2. Sloped Shed roof with Structural steel support frame.
    By billbe in forum Structure - General Questions
    Last Post: April 14th, 2015, 05:38 AM
  3. Glazed panel appearance issue...
    By thatsnagesh in forum Structure - General Questions
    Last Post: February 2nd, 2015, 10:28 AM
  4. noob help with singly sloped glazed skylight, not ridged
    By oompa_l in forum Architecture and General Revit Questions
    Last Post: March 6th, 2014, 09:38 PM
  5. Sloped Glazed roof by Face (mass) - other side
    By kubbah in forum Architecture and General Revit Questions
    Last Post: July 29th, 2013, 11:14 PM
