Results 1 to 4 of 4
Thread: How to get "Site" in my template
    February 9, 2018
    Va Beach, VA
    102
    07:02 AM
    I have been using the Residential default as a basis for my template.
    I would like to learn more about site.
    All the videos I watch, the site is in the floor plans.
    Would anyone know it it would be easy enough to add site to my template?
    Thanks!
    Gary
    February 9, 2018
    Va Beach, VA
    102
    07:02 AM
    Robin,
    Thanks for correcting the title.
    Yes, that is interesting.
    I think we mostly do dimension to the centers here. I also tag the window size.
    I wonder if it could be that different window manufacturers have different rough openings for their windows.
    I know some RO for some windows are the same as the window size as others are an inch or two larger in both directions. Different manufacturers-different rough openings for the same stated size window.
    And of course, our masonry is usually only a veneer, applied after the windows are set.
    When I was in ND, I looked and looked for any sign of a wood frame house, never to be found
    February 9, 2018
    Va Beach, VA
    102
    07:02 AM
    Coeur d Alene, ID
    4,744
    12:02 AM
    Quote Originally Posted by glkirk View Post
    Thanks!
    Gary
    I have a site level and then a Level 1....that way I can keep the topography set to the site level (0'-0") and move level 1 as needed without moving the topo.
  1. REVIT 2017 - DEPTH CUE - Can't click "show depth" / greyed out in view template
    By jmabbey in forum Architecture and General Revit Questions
    Last Post: June 14th, 2017, 02:11 PM
  2. Replies: 2
    Last Post: February 15th, 2016, 07:28 PM
  3. Replies: 0
    Last Post: April 28th, 2015, 11:15 AM
  4. Rebar Diameter symbol "Ø" is Showing as "0" in Revit 2014
    By Shefypattambi in forum Architecture and General Revit Questions
    Last Post: July 14th, 2014, 01:49 PM
  5. Door Family template - how to delete "pre defined" parameters (or change them)
    By Hilife in forum Architecture - Family Creation
    Last Post: April 23rd, 2013, 04:48 PM
