Results 1 to 3 of 3
Thread: Second floor not visible, nor the ceiling plans
  1.    #1
    Lurker
    April 14, 2019
    1
    06:47 AM
    Question Second floor not visible, nor the ceiling plans
    Hi guys, I am working on a restaurant design and I finished the first floor, however, when I go to the ceiling view or second floor plan, nothing shows up (even the reference points are missing)
    I tried everything Youtube threw at me and it still would not work...
    Your help is much appreciated
    Attached Thumbnails Attached Thumbnails Second floor not visible, nor the ceiling plans-floor-1.png   Second floor not visible, nor the ceiling plans-floor-2.png
  2.    #2
    July 7, 2011
    Rotterdam, Holland
    1,166
    02:47 PM
    My first guess. The level of the second floorplan and ceiling are way above your first floor plan so you don' t see anything with the view range you are using. Check in a section to see where you levels are and in the properties panel of you floorplan to see ho far you look down from the floor level.
    But it is hard to figure out from just 2 images.
  3.    #3
    Moderator DaveP's Avatar
    January 10, 2011
    St Paul, MN
    2,949
    07:47 AM
    First thing I always do when trying to look at height issues is to cut a Section.
    Verify that all Levels, Floors and Ceilings really are where you think they are.
  1. Staircase treads on floor plans and ceiling plans.
    By BIM Warrior in forum Architecture and General Revit Questions
    Last Post: September 20th, 2018, 10:49 AM
  2. Creating HVAC Layouts use ceiling plans or Floor Plans
    By fifthtexas in forum MEP - General
    Last Post: October 23rd, 2017, 09:58 PM
  3. Ceiling Grid To Show in floor plans
    By fifthtexas in forum Architecture and General Revit Questions
    Last Post: June 19th, 2015, 04:27 AM
  4. Floor Slabs and Stairs Missing in Reflected Ceiling Plans
    By Dennis.Barker in forum Architecture and General Revit Questions
    Last Post: November 26th, 2014, 09:26 PM
  5. Ceiling Grid visible in Floor Plans....
    By ThatBIMGuy in forum MEP - General
    Last Post: February 26th, 2014, 06:10 PM
