Results 1 to 3 of 3
Thread: copy paste detail items
  1.    #1
    February 9, 2018
    Va Beach, VA
    102
    12:35 PM
    I want to copy and paste detail items that used to detail a wall section. To ultimately set this into my template for easier detailing.
    I have tried it but it says I'm not pasting to the appropriate view. I am trying to paste to a new drafting view.
    I suspect that there might be a part of the model in the section. If that is the case, does anyone know how to isolate out all of the model?
    Thanks,
    Gary
  2.    #2
    July 7, 2011
    Rotterdam, Holland
    1,166
    02:35 PM
    use the filter selection button
  3.    #3
    Orlando, FL, USA
    3,087
    08:35 AM
    After you filter to select only detail items as indicated above, instead of copy-pasting create a detail group. Then, go to the drafting view and insert the detail group. Then, from the template file, you can use Insert > Views from file, and insert this drafting view with the detail group into your template.
  1. Combined group with detail items and model items - won't move together
    By katewood1989 in forum Architecture and General Revit Questions
    Last Post: February 15th, 2018, 03:55 PM
  2. copy & paste detail group from one plan view to another plan view (2017)
    By ledgewood33 in forum Architecture and General Revit Questions
    Last Post: November 29th, 2016, 08:07 PM
  3. I want my detail items placed in my sections to show up in my Detail Views!!
    By ecraider in forum Architecture and General Revit Questions
    Last Post: April 13th, 2015, 01:51 PM
  4. Copy/Paste
    By Bjenk8100 in forum Architecture and General Revit Questions
    Last Post: November 4th, 2013, 06:31 PM
  5. Copy & Paste (align) Detail view section cuts
    By bigmatty55 in forum Structure - General Questions
    Last Post: March 15th, 2013, 01:09 PM
