Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By Twiceroadsfool
Thread: Area Plans on Plans Other Than Floor Plans
    "OMG I killed Revit"
    dzatto's Avatar
    December 9, 2010
    5,234
    12:59 AM
    Okay, here's my dilemma. I need to do an area plan on my foundations. I can't use the floor plan because I have different foundations offsets (12-18" drops where the lower slab extends beyond the upper slab opening). I can't just click on each slab because I create my stone ledges using slab edges. So, technically, the slab ends 5.5" short of the edge of slab. I can't create an area plan of the same view because the area boundaries carry over and can' be deleted without deleting them in both views (I already have an area plan for my finished floor for example). I know I can switch to gross vs rentable, but again, I'll need to do two area plans for the same floor plan and that can't be done. If I create a new floor plan view, it won't show up in the area plan dialogue box (I think that's populated by level, not by plan view).
    Any ideas I'm not thinking of?
    dzatto's Avatar
    December 9, 2010
    5,234
    12:59 AM
    I guess I could just export to ACAD and draw a polyline. I'd rather keep it in Revit though...
    10,276
    12:59 AM
    You just create addition Area Schemes. You can make as many as you need.
    dzatto likes this.
    dzatto's Avatar
    December 9, 2010
    5,234
    12:59 AM
    Well damn, I've never had to add a scheme. Makes sense though.
    So what populates the area dialogue box? Levels? I'm assuming I'll need to create an upper slab and lower slab scheme since I can't use the same level twice, correct?
    10,276
    12:59 AM
    Yep. BTW, this all assumes what you are doing SHOULD be done with areas. I didnt read that closely. Just realized what you were trying to do and answered with what is possible.
    dzatto's Avatar
    December 9, 2010
    5,234
    12:59 AM
    I got it working. And I'm assuming it should be done with areas since I can't just schedule the area of the slab because I create my brick ledges using slab edges. Unless there's something else I'm not thinking of? It sucks I have to outline a 13K sf slab but it is what it is. lol
    Thanks Aaron.
    Member PatrickGSR94's Avatar
    July 7, 2017
    Hernando, MS
    496
    12:59 AM
    You might ought to look at how you're modelling the slab and slab edges to see if you can change it so that a schedule will report the correct area you're looking for. Do it once and then it'll be a WHOLE LOT faster in the future. Maybe a sketch or 3D screen shot would help us offer suggestions.
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,164
    01:59 AM
    You can also create a new area plan based on a lower level (if available), and change your view range.
  1. Staircase treads on floor plans and ceiling plans.
    By BIM Warrior in forum Architecture and General Revit Questions
    Last Post: September 20th, 2018, 10:49 AM
  2. Using area plans instead of floor plans
    By Whatuser in forum Architecture and General Revit Questions
    Last Post: June 4th, 2018, 01:00 AM
  3. Creating HVAC Layouts use ceiling plans or Floor Plans
    By fifthtexas in forum MEP - General
    Last Post: October 23rd, 2017, 09:58 PM
  4. Difference Between Floor Plans and Structural Plans
    By MARIA1993 in forum Architecture and General Revit Questions
    Last Post: October 25th, 2016, 04:39 PM
  5. Area plans used for all floor plans?
    By joeyd in forum Architecture and General Revit Questions
    Last Post: April 6th, 2015, 06:46 PM
