Results 1 to 2 of 2
Thread: Some masses cast shadows, some don't
  1.    #1
    April 3, 2014
    41
    12:17 PM
    We're trying to create a conceptual site plan. We're using simple masses to show schamatic architecture in the area.
    The properties of all masses are set by deafult. Yet some of them cast shadows, and some other don't. I can't locate what's the difference between them and why is this happening. Below is our site (floor plan) view:
    FI there are no shadows in 3d view:
    All masses properties seems to be the same:
    The mass on the right only displays shadow when clicked on...
    There are no overrides in V/G, no individual overrides, no filters applied...
    Any thoughts?
    Attached Thumbnails Attached Thumbnails Some masses cast shadows, some don't-przechwytywanie3.jpg   Some masses cast shadows, some don't-przechwytywanie.jpg   Some masses cast shadows, some don't-przechwytywanie2.jpg   Some masses cast shadows, some don't-przechwytywanie4.jpg
  2.    #2
    Junior Member scourdx's Avatar
    July 4, 2013
    32
    05:17 AM
    Change the massing material to solid material.
  1. How To: Export an Image with Only Shadows (Cast or Ambient)
    By billiam in forum Tutorials, Tips & Tricks
    Last Post: March 1st, 2019, 01:20 AM
  2. 2015- railing balusters do not cast shadows and no glazing transparency
    By danbush in forum Architecture and General Revit Questions
    Last Post: September 27th, 2018, 02:25 PM
  3. BIM for Cast-in-stone walls
    By billiam in forum Architecture and General Revit Questions
    Last Post: July 24th, 2014, 08:24 PM
  4. What screen cast prg do you use
    By jh75 in forum Out There
    Last Post: February 14th, 2013, 04:45 AM
  5. Context Masses Visible Good, Concept Masses Visible Bad
    Last Post: June 14th, 2011, 05:11 AM
Tags for this Thread
