Results 1 to 7 of 7
Thread: Revit Defaut Shared Parameter location
    March 27, 2019
    4
    09:51 PM
    Hi, I've been using 3rd party software inside Revit, so in my Shared parameter only shows the shared parameter for that software.
    What is the path for the defaut Revit shared parameter .
    Gold Coast
    2,609
    07:51 AM
    Quote Originally Posted by Rocha81 View Post
    https://www.revitforum.org/architect...-location.html
    Member TFuller's Avatar
    March 7, 2014
    Evansville, IN
    361
    04:51 PM
    I don't think there is one. You create your own and tell Revit where to look for the file. From there, it remembers the last place.
    March 27, 2019
    4
    09:51 PM
    Thomas,
    I might be overthinking but I was looking for the shared paramater text file that has the Groups (Identity Data, Text, Other). As of right now this is what I see. Before I used to see all the Revit groups.
    Attached Thumbnails Attached Thumbnails Revit Defaut Shared Parameter location-revit-forum.png
    March 7, 2014
    Evansville, IN
    361
    04:51 PM
    You would be creating your own groups. These groups are for your internal organization only. When adding a SP to family or a project, you still have to specify what group the parameter is placed in for that file.
    March 7, 2014
    Evansville, IN
    361
    04:51 PM
    If you want the groups that Revit uses in its files, (i.e. the list you stated), you'd have to create them in a blank file or copy an existing file that happens to have them.
    March 7, 2014
    Evansville, IN
    361
    04:51 PM
    Try this on for size...
    Attached Files Attached Files
  1. Shared parameter file location
    By Brocha in forum Architecture and General Revit Questions
    Last Post: February 10th, 2016, 06:51 PM
  2. Replies: 0
    Last Post: January 13th, 2016, 02:45 AM
  3. Replies: 0
    Last Post: January 12th, 2016, 05:45 AM
  4. Replies: 0
    Last Post: January 11th, 2016, 04:45 AM
  5. Replies: 0
    Last Post: August 11th, 2011, 07:20 PM
