Page 5 of 8 FirstFirst 12345678 LastLast
Results 41 to 50 of 74
Like Tree30Likes
Thread: Revit 2020 Download?
  1. #41
    Member CRapai's Avatar
    April 30, 2015
    Michigan
    220
    04:54 PM
    Quote Originally Posted by CRapai View Post
    This one scares me because I don't understand what their talking about and it sounds like a fix that could break several other things. Maybe even ruin jank workarounds.
    Thanks for the reassurance.
  2. #42
    May 29, 2017
    16
    03:54 PM
    I dunno...shows as a Install - Issue Resolved in the Release Notes. Could be Support won't be able to help you if you cannot install 2020 on a Windows 8 machine..
    Sure enough. It isn't listed on the requirements.
  3. #43
    May 29, 2017
    16
    03:54 PM
    So, yay! We can install a brand new program on an 8 year old OS!!
    Not really my call. They just started phasing in Windows 10 with new machines recently. Most are still on Window 7 SP1. But it looks like it will be our call if we want to move up to Revit 2020 or any version in the future.
  4. #44
    April 30, 2015
    Michigan
    220
    04:54 PM
    I think very recently windows 10 finally overtook 7 in market share.
    elton williams and mschirmer like this.
  5. #45
    September 4, 2013
    1
    10:54 PM
    Hmm... I have my license of Revit, but I still cannot save in this new 2020 version. When I try to save a file it says "Revit 2020 is in viewer mode". Does it take some time for this to work?
    Same around here.
    Does anyone have a fix? I've checked the shortcut in the icon, but it was correct. So there's no reason to be in viewer mode.
  6. #46
    Orlando, FL, USA
    3,093
    04:54 PM
    Quote Originally Posted by Rigel View Post
    Same around here.
    I received a response to my question about this from an Autodesk representative. He directed me to this article: https://knowledge.autodesk.com/searc...licensing.html
    I followed instructions, but after that, my Revit 2020 continues to be in viewer mode.
  7. #47
    Member Geert's Avatar
    February 8, 2011
    Les Vigneaux, Hautes Alpes, France
    143
    10:54 PM
    Still hasn't appeared in the desktop app over here.
  8. #48
    Moderator DaveP's Avatar
    January 10, 2011
    St Paul, MN
    2,965
    03:54 PM
    Alf, is this a stand-alone license or a networked?
    If it's network, you'll usually need a new version of FlexLM to go with the new version of Revit.
    Although, I've never quite understood why. As far as I can tell, FlexLM isn't really doing anything different. They UI certainly hasn't changed in 10 years.
  9. #49
    Orlando, FL, USA
    3,093
    04:54 PM
    Thanks. It is a stand-alone commercial license, monthly subscription.
  10. #50
    Coeur d Alene, ID
    4,744
    01:54 PM
    Someone mentioned that the standalone licensing would not be available for a couple of weeks ....but if it shows at your Manage portal, then it should be working.
    I got nothing so far....so no sense installing if I can't enter a serial number.
  1. Autodesk 2020
    By cftrevizo in forum Architecture and General Revit Questions
    Last Post: April 10th, 2019, 06:07 PM
  2. Replies: 0
    Last Post: May 10th, 2017, 03:15 AM
  3. What Revit Wants: 3D DWG to RFA addin for download
    By luke.johnson in forum Blog Feeds
    Last Post: January 23rd, 2014, 11:15 AM
  4. Replies: 0
    Last Post: December 3rd, 2012, 01:15 AM
  5. Replies: 0
    Last Post: September 21st, 2011, 11:20 AM
