Page 4 of 8 FirstFirst 12345678 LastLast
Results 31 to 40 of 74
Like Tree30Likes
Thread: Revit 2020 Download?
  1. #31
    Coeur d Alene, ID
    4,817
    08:32 AM
    Honestly, with the amount of money my company is making working for GC's, solving issues because people are tracing CAD since they dont know any better, i think i might actually be able to retire early, off the mess thats going to happen when people start tracing PDF's.
    If you need help let me know.
    tidalwave1 likes this.
  2. #32
    10,362
    10:32 AM
    I need help.... that lives in Dallas.
    GMcDowellJr and tidalwave1 like this.
  3. #33
    September 19, 2017
    Seattle, WA
    57
    08:32 AM
    I haven't downloaded it yet, but a few things look promising:
    "Improved the nested family connector location so that it is properly located as defined in family definition instead of at origin." (Now if only we could turn connectors off!)
    "Added two new filter operators, "parameter has value" and "parameter has no value", that allow filtering elements based on one of the parameters having a value or being empty."
    Improved behavior to retain the element location when changing the Level property, updating the Elevation from Level property instead" (So annoying and inconsistent)
    "Added the ability to schedule and use view filters for level parameter with air terminals, fittings, accessories, and plantings" (Y no duct??? /s But filtering anything "underfloor" in a ceiling would be awesome. Not so easy right now)
    Of course, there's no guarantee I'll get to use this release anytime soon. most of our projects are still in 2018.
  4. #34
    Coeur d Alene, ID
    4,817
    08:32 AM
    Ha ha....figures you would say that. Actually enjoyed my trip over there last year...moving may be an option if the work was worthwhile.
  5. #35
    Gold Coast
    2,631
    01:32 AM
    I always enjoy reading the bug fixes
    Help
    a few of my favs-
    Fixed an issue where an IF statement formula used in a text parameter could produce inconsistent results.
    Fixed an issue that resulted in a tag on a floor element not updating the top/bottom core elevation when updating the Project Base Point elevation.
    Fixed an issue where symbols print differently when nested in a family than when they are placed directly in the model.
    Improved Temporary View Properties view mode to allow changing the design option while in the mode.
  6. #36
    Moderator DaveP's Avatar
    January 10, 2011
    St Paul, MN
    3,021
    10:32 AM
    This one's my fav:
    Fixed a typo in the Upgrade dialog when opening a model.
    Whew! Guess I dodged a bullet by not running into that one!
  7. #37
    Member CRapai's Avatar
    April 30, 2015
    Michigan
    258
    11:32 AM
    Help
    a few of my favs-
    This one scares me because I don't understand what their talking about and it sounds like a fix that could break several other things. Maybe even ruin jank workarounds.
  8. #38
    10,362
    10:32 AM
    Quote Originally Posted by CRapai View Post
    It won't break any workarounds, because it wasn't anything you could leverage.
    A symbol placed in a family that was loaded in a project, would have darker and less anti aliased lines than if the symbol was just placed in project. It was ******.
    elton williams likes this.
  9. #39
    Senior Member
    December 16, 2010
    871
    01:32 AM
    Quote Originally Posted by Geert View Post
    The whatsnew is online:
    https://blogs.autodesk.com/revit/201...in-revit-2020/
    pdf underlays
    No slanted walls yet, but we got elliptical walls :-)
    You can make slanted walls already.... use "wall by face" and select a conceptual volume (that you prepared earlier).
  10. #40
    Member Geert's Avatar
    February 8, 2011
    Les Vigneaux, Hautes Alpes, France
    145
    05:32 PM
    I know, but it was on the roadmap
  1. Autodesk 2020
    By cftrevizo in forum Architecture and General Revit Questions
    Last Post: April 10th, 2019, 06:07 PM
  2. Replies: 0
    Last Post: May 10th, 2017, 03:15 AM
  3. What Revit Wants: 3D DWG to RFA addin for download
    By luke.johnson in forum Blog Feeds
    Last Post: January 23rd, 2014, 11:15 AM
  4. Replies: 0
    Last Post: December 3rd, 2012, 01:15 AM
  5. Replies: 0
    Last Post: September 21st, 2011, 11:20 AM
