Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Like Tree1Likes
Thread: Loading an early-version revit family.
  1.    #11
    June 11, 2012
    Portsmouth
    55
    01:56 PM
    Don't know why you couldn't just used one sweep instead of 4 sweeps and 4 corner objects.... Must have a good reason.
    Learning curve. I created the objects, made them flex and then added them to the model. Started small and then built the model. Thanks for the advice.
  2.    #12
    June 11, 2012
    Portsmouth
    55
    01:56 PM
    MP
    I dismantled my model and found some awful errors so I started again. The sweep did not work when the structural edges were changed so I changed to an extrusion.
    Fingers crossed, does this model work please and I really do appreciate the time you are giving me.
    Attached Files Attached Files
  3.    #13
    Coeur d Alene, ID
    4,697
    05:56 AM
    Better...and I like that it stretches from one point. Also whatever you did file size was half of what it was before.
  4.    #14
    June 11, 2012
    Portsmouth
    55
    01:56 PM
    Thanks. I have no idea why the file-size was smaller. May be due to the omission of the EQ dimensions.
  1. Replies: 0
    Last Post: September 6th, 2018, 01:15 AM
  2. Loading of Diffuser family
    By zacoolm in forum MEP - General
    Last Post: April 22nd, 2013, 07:54 PM
  3. Replies: 0
    Last Post: August 16th, 2012, 03:15 AM
  4. Loading Family (Doors)
    By amahp in forum Architecture and General Revit Questions
    Last Post: April 2nd, 2012, 10:17 PM
  5. loading family
    By Tom Dolle in forum Architecture and General Revit Questions
    Last Post: March 23rd, 2012, 04:03 PM
