Page 2 of 6 FirstFirst 123456 LastLast
Results 11 to 20 of 55
Like Tree62Likes
Thread: Revit to CAD
  1.    #11
    10,036
    09:31 PM
    What it sounds like she is after, is a DWG set of the project that is actually assembed in AutoCAD, the way we used to do projects in AutoCAD: One Base, multiple viewports, and multiple sheets.
    Revit is NEVER going to create that for you, even with Dynamo.
    Any way that you tell Revit to export two plans to CAD, they are coming out with duplicate data, because the concept of XREF doesnt work the same in a Revit made CAD export, and a native AutoCAD File.
    If she is that hell bent on getting USEABLE files in DWG, the job needs to be done in AutoCAD, or redone in autocad after the fact.
  2.    #12
    Member PatrickGSR94's Avatar
    July 7, 2017
    Hernando, MS
    442
    09:31 PM
    Man, talk about someone with blinders on. I'm not sure I could handle that. How is it that your company is even paying for Revit seats if she thinks it's so bad?
    tidalwave1 likes this.
  3.    #13
    June 21, 2012
    Tours, France
    937
    04:31 AM
    Quote Originally Posted by PatrickGSR94 View Post
    Well actually that's a very good point, we have here 3 Projects Chiefs which are trained in basic Revit, problem is that they argue that they don't have the time to continue to learn so the drafter are stuck in a kind of limbo because if the Chief don't want to do nothing with revit so the drafter cant do more.
    So we have 3 Project Chiefs that don't open revit even to try to do a basic operation, 4 Drafters which want to work with revit but can do nothing abut it, 1 BIM manager (Me ) whom is doing all he can to push this up but with no luck.
    Just to give you more clues about my problem here, last week I was asked to do some Facades in Photoshop, I've started to do those facades in ACAD since I consider that is the tool to draw facades and since she realized he wasn't "drawing" with photoshop that drove her crazy!! I just reply to her argument by saying that acad is the tool to draw facades and photoshop is to modify photos!!
  4.    #14
    June 21, 2012
    Tours, France
    937
    04:31 AM
    ..Revit is NEVER going to create that for you, even with Dynamo....
    That's what I've thought!
    .If she is that hell bent on getting USEABLE files in DWG, the job needs to be done in AutoCAD, or redone in autocad after the fact.
    Yes I guess that is the only solution
  5.    #15
    Gold Coast
    2,602
    12:31 PM
    just for the record. Dynamo WILL do what I described, but not what Aaron said as something like a truly autocad workflow. Brains trust enabled
    Andres Franco likes this.
  6.    #16
    June 21, 2012
    Tours, France
    937
    04:31 AM
    Quote Originally Posted by Robin Deurloo View Post
    I think I have the best solution for you, GET ANOTHER JOB !!
    Frankly Yes!! since she wants that Revit to do the same as Acad! and I've explained that those are a very different programs that do things in a very different way!!
  7.    #17
    July 7, 2011
    Rotterdam, Holland
    1,169
    04:31 AM
    Not sure how the construction market is in France, but here in Holland, a mediocre Revit guy will have a new job within a week I think, with a large contractor for example and will get extra educated by that contractor to become a good Revit guy. If you are already good you can most likely name your price
  8.    #18
    June 21, 2012
    Tours, France
    937
    04:31 AM
    Well it seems that I need to move to Holland!!, but my only problem is that I not French either !!
  9.    #19
    July 7, 2011
    Rotterdam, Holland
    1,169
    04:31 AM
    How can not being French be a problem ??
    Seems like a big advantage to me
    Andres Franco and Dave Jones like this.
  10.    #20
    June 21, 2012
    Tours, France
    937
    04:31 AM
    nice one!!
    By the way I not consider myself as a genius but certainly I'm not a mediocre Revit guy
Tags for this Thread
