Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Like Tree16Likes
Thread: Autodesk 2020
    January 19, 2012
    325
    04:21 PM
    Autodesk 2020
    I'm starting to see some of the Products have 2020 versions. That must be in 2-3wks Revit will come. Can't wait
    Member tidalwave1's Avatar
    December 9, 2010
    Las Vegas
    113
    02:21 PM
    I was wondering when the Revit 2020 posts would come... lol
    Moderator DaveP's Avatar
    January 10, 2011
    St Paul, MN
    2,965
    04:21 PM
    If there was a beta program and if, theoretically, I was on this imaginary program, then I would be restricted by NDA from telling you there might be some things you'll like, some you won't care about, and some you'll wonder why they still haven't done.
    If I were to be specific, anyway.
    therrien, FBlome, Hirvio and 6 others like this.
    July 7, 2011
    Rotterdam, Holland
    1,200
    11:21 PM
    So theoretically, basically the same as almost every year then?
    And I have AutoCAD LT 2020 running, but haven't looked at the 2019 version good enough to see what has changed as I try to get out of that program asap most of the time
    Coeur d Alene, ID
    4,744
    02:21 PM
    We have BDS Premium....won't be seeing anything 2020 for a while.
    May 29, 2017
    16
    04:21 PM
    I'm curious what the upgrade timeline is with everyone? I have made the decision to upgrade every 3 years. Right now we are in AEC 2018.
    July 7, 2011
    Rotterdam, Holland
    1,200
    11:21 PM
    I pretty much upgrade every year, but usually start doing money making projects after the first service pack (or whatever Autodesk calls them), so most of the time during summer. This year most of my projects are still in 2018 because I have 3th parties to think about. One of them is going to do all their new project in 2020 somewhere during summer, so I will be doing their projects in 2020 from that time as well (they skipped 2019).
    I will be trying to run new projects in 2020 from summer, but it depends on 3th parties again.
    Gold Coast
    2,609
    07:21 AM
    We have AEC collection licences and I'm seeing a couple of flavours of autocad 2020 today. Downloaded and installed on my machine.
    Previously I've waited at least for the first service pack in any release before rolling it out (and waiting to be informed by others) but I'm starting to think ill just crack it open when Revit 2020 is released and see what happens. Obviously I won't get new projects started on it straight away.
    I'm not that worried about addins because I see them as time savers rather than anything to do with something that can't be done natively, even if it takes longer, although I must say I don't (yet) rely on things like CTC. When the app/s gets updated then cool, things should speed up again.
    Member Knitro87's Avatar
    December 3, 2014
    Austin, TX
    279
    04:21 PM
    If a firm's only real need for AutoCAD is to occasionally open a civil DWG file, is there any reason to keep multiple versions installed? DWG files are backwards compatible, therefore they can be opened/accessed with the latest version.
    Gold Coast
    2,609
    07:21 AM
    Quote Originally Posted by Knitro87 View Post
    We use autocad to open all sorts of consultants files. Usually to remove crap floating off in the distance. Backwards compatibility is also why I have no hesitation in installing it straight away.
    i know barely enough about autocad to scrape by, and zero about the program's development, except that they are regularly leading the way with version releases. I just see autocad as the most long standing traditional user group so I guess that's why they're still at the front of the line.
  1. Replies: 0
    Last Post: March 22nd, 2016, 11:15 AM
  2. Replies: 0
    Last Post: November 4th, 2015, 11:45 AM
  3. Replies: 0
    Last Post: June 2nd, 2015, 11:15 AM
  4. Replies: 0
    Last Post: January 15th, 2014, 11:15 AM
  5. Replies: 0
    Last Post: August 5th, 2011, 11:11 AM
