Results 1 to 9 of 9
Like Tree3Likes
  • 1 Post By DavidLarson
  • 2 Post By DavidLarson
Thread: How to create a klip-lok Roof in revit
    March 26, 2019
    2
    05:29 PM
    Red face How to create a klip-lok Roof in revit
    Hi All,
    Im very new to revit, just transitioned from Autocad! and needing a little help
    I have created a roof by footprint using the Basic Roof - generic 125mm roof provided in revit 2019 however i want to change the roof construction to a klip-lok roof so it is represents the correct material and profile in the 3D model...
    Any ideas how this can be achieved?
    Thank you in advance
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,190
    11:29 AM
    I'm assuming Klip-Lok is a standing seam roof? Google tells me it is the Lysaght product: https://www.lysaght.com/products/klip-lok-classic-700 but it has lied to me in the past
    Lysaght has some content on their site: https://professionals.lysaght.com/re...s/cad-drawings It looks like they are profiles - so you would need to convert it into a family.
    That said - for standing seam roofs I usually use sloped glazing with a custom mullion for the seams. You can read a bit about it here: https://help.autodesk.com/view/RVT/2...Id-100332.html
    March 26, 2019
    2
    05:29 PM
    Alright, ill check it out! thank you so much
    Gold Coast
    2,631
    01:29 AM
    Chad, yes kliplok is like standing seam and is very popular for commercial applications in Aus.
    Can you put metal deck profiles into roofs like you can with structural floors?
    edit, I guess not, but I'd rather do this (see link) unless I needed to render it - and as long as the profile still showed up in non perpendicular cuts! (ie vertical section, sloped profile)
    https://www.revitforum.org/architect...ural-deck.html
    July 10, 2015
    Boise, Idaho
    700
    09:29 AM
    I make all my standing seam roofs with sloped glazing. The ribs are mullions, the flat sections are the panels. I only show the major ribs since the minor ones won't show enough to make up for the increased complexity.
    GMcDowellJr likes this.
    Senior Member biff's Avatar
    June 13, 2011
    Australia
    850
    01:29 AM
    If you want the render appearance and profile etc, go to www.steelselect.com. You can download the adsklib there flr all lysaght cladding products as well as gutter profiles etc. Great resource, pity Michael who developed it has moved on but it is still there.
    July 10, 2015
    Boise, Idaho
    700
    09:29 AM
    Here let's make it easy. Swap out the mullion profile for whatever you want.
    Attached Files Attached Files
    biff and cellophane like this.
    May 19, 2011
    108
    12:59 AM
    Thanks Biff, I'm still around the place but yes no longer associated with SteelSelect in anyway. I hope all is well.
    June 13, 2011
    Australia
    850
    01:29 AM
    Except I got your name wrong!
  1. Maybe you don't know - How to create Roof at Stair into Revit
    By paultran in forum Tutorials, Tips & Tricks
    Last Post: April 27th, 2017, 07:49 AM
  2. Cannot create Mass Roof
    By thaihoalu in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: October 23rd, 2015, 01:53 AM
  3. Replies: 0
    Last Post: May 20th, 2013, 03:45 AM
  4. Replies: 0
    Last Post: May 18th, 2013, 07:15 AM
  5. Trick Question: How to create this roof in 'Revit'
    By Tim West in forum Architecture and General Revit Questions
    Last Post: August 13th, 2012, 01:52 PM
