Results 1 to 5 of 5
Like Tree1Likes
  • 1 Post By cellophane
Thread: Pushing one parameter to another if third parameter is true
  1.    #1
    March 15, 2019
    2
    01:26 AM
    Hey there, i was wondering if it is possible, to make a calculated value in a schedule, from an other paramater, which has the same value as another parameter, but i only want the parameter if a third parameter has a special value.. I know this sounds weird, but here as a if example
    If param "Value" is = to "Yes" then "Value2" = "Value1"
    Is this doable, and how may that if statement look like? Hope i make any sense
  2.    #2
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,055
    08:26 PM
    https://www.revitforum.org/tutorials...day-usage.html
    if(Value>0,Value1,0)
    if Value is greater than 0, then use Value1, otherwise 0
    Andres Franco likes this.
  3.    #3
    March 15, 2019
    2
    01:26 AM
    Thx so much for showing me, i want to learn But its seems that its a bit mor complicated than that i put a picture, to try and tell what i wanna do, maybe you could write me how the code would look in context?
    Attached Thumbnails Attached Thumbnails Pushing one parameter to another if third parameter is true-2019-03-16-10_44_02-autodesk-revit-2019.2-%5Bpfa-sk_ark-01_phh%5E-schedule_-area-schedule-gross.png
  4.    #4
    Forum Addict Robin Deurloo's Avatar
    July 7, 2011
    Rotterdam, Holland
    1,093
    01:26 AM
    I dont think you can not use the type parameter in a formula.
  5.    #5
    Mr. Revit OpEd
    2,830
    05:26 PM
    I looks like you're dealing with occupancy calculations. Search the forum for that subject, you'll find some in depth replies that should help with that task.
  1. Replies: 0
    Last Post: January 11th, 2018, 01:45 AM
  2. Replies: 0
    Last Post: January 10th, 2018, 07:15 AM
  3. Replies: 0
    Last Post: February 10th, 2016, 08:15 AM
  4. Replies: 0
    Last Post: December 24th, 2015, 09:16 PM
  5. select by parameter? curtain wall panels' materials by parameter, by type or family?
    By oompa_l in forum Architecture and General Revit Questions
    Last Post: January 24th, 2013, 03:20 PM
