Results 1 to 10 of 10
Thread: Schedule Linked Models
    October 10, 2017
    United Kingdom
    6
    04:41 AM
    Guys,
    Does anyone know how I can create a schedule that shows the linked models in a project?
    I'm simply looking for the schedule to show:
    File Name - Revision
    10,186
    11:41 PM
    Revision meaning......?
    October 10, 2017
    United Kingdom
    6
    04:41 AM
    The current version of the file. P01,P02,P03 etc.
    Senior Member
    December 16, 2010
    856
    02:41 PM
    Just include the revision in the file name.....
    PROJECT HOSPITAL_P03.RVT
    You should probably be archiving key revision files anyhow...
    October 10, 2017
    United Kingdom
    6
    04:41 AM
    We do, the issue we have is we need to show on the drawing which linked models are being displayed on the drawing.
    November 2, 2011
    Slaithwaite ("Sla wit"), W Yorks, UK
    245
    05:41 AM
    We needed this capability on a Revit 2016 project last year, but at the time it was not supported out of the box. We were required to show which versions of the host and linked files were used to generate each individual plot. We worked around it by creating a legend that was included on every sheet and which we manually updated each time a new version of a linked file was created. We had a different legend for each scale so that the drawing sheet did not end up showing "As indicated" for the drawing scale. It was a trivial amount of work to manually update. I suspect that it would be easily automated through Dynamo, though.
    I think that from Revit 2018 the linked file project parameters are available to schedule, but I've not explored this option. If so, it could be automated.
    10,186
    11:41 PM
    Quote Originally Posted by dig_eng_stu View Post
    Oh, interesting. I thought you were talking about drawing revisions like a sheet list.
    Opinions vary, but my file names don't ever change on a project, so it would have to be done as a shared parameter in project information (if that's possible to schedule as a link). If not, it would be a manual thing, for us. There aren't a ton of models, and generally (most of the time, here) they all change issuance together so it's not much of an issue.
    February 10, 2011
    35
    11:41 PM
    Another thing you can do, along the lines of Aaron's method, is create multiple parameters (e.g. per bid pack) and track when sheets are for reference only, not included or where first included in a bid pack, in a matrix-type sheet schedule. Parameter value examples might be: X = included, R = Reference only, blank or "---" = not included.
    February 10, 2011
    35
    11:41 PM
    On this topic, I just wrote this post https://bimchapters.blogspot.com/201...tiple-bid.html
    May 30, 2015
    201
    11:41 PM
    It would be interesting to consider this idea/topic in relationship to BIM360 which already tracks model versions.
  1. Linked Models
    By michealwaldron in forum Architecture and General Revit Questions
    Last Post: March 17th, 2017, 07:43 PM
  2. Schedule hell - Showing only one level per linked file, AND Comparing schedule data
    By kescr in forum Architecture and General Revit Questions
    Last Post: March 8th, 2016, 09:35 PM
  3. linked door schedule vs linked room schedule
    By Ning Zhou in forum Architecture and General Revit Questions
    Last Post: April 1st, 2015, 01:51 AM
  4. Rooms in Linked Models
    Last Post: January 8th, 2013, 06:12 PM
  5. Schedule from Linked Models
    By Grady in forum Architecture and General Revit Questions
    Last Post: November 14th, 2012, 07:47 PM
