Results 1 to 8 of 8
Thread: Edit Leader Line
  1.    #1
    April 30, 2015
    Michigan
    177
    05:02 PM
    Question Edit Leader Line
    Is it possible to change the leader line? There is some desire in the office to get our tag looking like this (yes, I know, it's CAD. I know.):
  2.    #2
    December 21, 2010
    Phoenix, AZ
    2,514
    02:02 PM
    no... what is that supposed to be btw?
  3.    #3
    December 21, 2010
    Phoenix, AZ
    2,514
    02:02 PM
    You could, however, make your own as a line-based detail item -- you'll need a way to manage scale -- I use an instance parameter but you could have multiple types as well
  4.    #4
    Forum Addict Robin Deurloo's Avatar
    July 7, 2011
    Rotterdam, Holland
    1,093
    10:02 PM
    Not as far as I know. You can choose between a few arrow heads and customise those to some extent, but that's it.
    So the black arrow is no problem the wiggly line before that is not possible I think.
  5.    #5
    9,912
    04:02 PM
    Somebody intentionally wants that goofy leader line? Is this legit?
  6.    #6
    Moderator DaveP's Avatar
    January 10, 2011
    St Paul, MN
    2,898
    04:02 PM
    I know this is not what you're looking for, but just in case someone else stumbles across this post:
    The OOTB Object Styles have one lineweight setting for each Tag. That controls the weight of the Leader and any lines in the Tag.
    We wanted our Leaders to be a lighter lineweight than the graphics of the Tag, so we've got a sub-category in ALL of our Tags called Tag Linework
    The Leader ONLY uses the Lineweight to the top-line category, but by using a sub-category for everything else, we can have a thin Leader and a bold box
    Edit: and, yeah, that squiggle??? Can't blame that on CAD. That's someone's (probably ancient) "standard"
  7.    #7
    Mr. Revit OpEd
    2,832
    02:02 PM
    Looks like an equipment tag and the leader is being used to impart some of the symbol related to its application, like supply, return etc.
  8.    #8
    July 10, 2015
    Boise, Idaho
    611
    03:02 PM
    I used to work in a reprographics shop while I was in college. Not once can I recall having ever seeing any such thing. If that's a standard it was somebody going completely off the rails. I printed stuff going back to the early 1900s too.
  1. leader line offset from object
    By baggins79 in forum MEP - General
    Last Post: November 30th, 2016, 02:39 PM
  2. How to edit leader lines and arrows
    By Lox in forum Architecture and General Revit Questions
    Last Post: April 13th, 2016, 04:54 AM
  3. Putting a Leader line onto a text box
    By Ral831 in forum Tutorials, Tips & Tricks
    Last Post: June 13th, 2014, 12:20 AM
  4. Replies: 0
    Last Post: November 26th, 2013, 04:45 AM
  5. Text & leader line thickness
    By jean_francois_nant in forum Architecture and General Revit Questions
    Last Post: October 31st, 2013, 09:13 PM
