Page 1 of 2 12 LastLast
Results 1 to 10 of 15
Like Tree2Likes
Thread: Document has changed since last version?
    Member PatrickGSR94's Avatar
    July 7, 2017
    Hernando, MS
    492
    12:19 AM
    Yesterday afternoon I opened a Central file through Recent Files, which went through the usual process of asking me to overwrite my local file. After everything was opened and loaded I saw this message:
    Now this morning I just opened another file through the same process, and got the same message again. No one else is working in these files, and they have not been saved at any other time except by me. After I close the message everything seems to work fine. Why would it bring up such a message?
    Moderator DaveP's Avatar
    January 10, 2011
    St Paul, MN
    2,980
    12:19 AM
    Yikes!
    I get scared, too, when I see an invisible error message!
    July 7, 2017
    Hernando, MS
    492
    12:19 AM
    Okay well I pasted a screen shot and it showed up as I was making the post. This is the message.
    Attached Thumbnails Attached Thumbnails Document has changed since last version?-document-changed.jpg
    10,186
    12:19 AM
    Not a good situation. It does that if you are in a file twice, and one of them becomes stale. You can make it do it with a family really easily. If that's happening when you're in a local of a central, I would suspect something isn't right with the file pathing, or that Revit thinks you are doing a save as, and not a swc.
    July 7, 2017
    Hernando, MS
    492
    12:19 AM
    I have no idea how any of that could be happening. I always SWC as normal using the button on the QAT, and all files are pathed with UNC path names i.e. \\server\share as opposed to mapped drive letters. And with 2019 I'm always opening a file from the Recent Files list which of course points to the Central file on our server and automatically creates a new local file each time.
    *edit* and if I close out of the file, close Revit, re-open and then re-open the file, there are no problems at all. It's only happened twice that I've seen, so far - once yesterday and once today, each on separate project files.
    July 7, 2017
    Hernando, MS
    492
    12:19 AM
    Looked through journal files, and there are definite differences between instances of opening a file with the error message and one opening normally, but I don't know enough about the code to be able to tell why there would be a difference.
    Member pivoarch's Avatar
    March 16, 2011
    Princeton, NJ
    306
    01:19 AM
    I've always trained people to never open files with the recent files window. At some firms, I had gone as far as disabling it.
    10,186
    12:19 AM
    Regardless of if you USE the Drive Letters, are they on your machine at all? IE: IS there a drive letter going to that server share, on your server? Or none at all?
    January 10, 2011
    St Paul, MN
    2,980
    12:19 AM
    Quote Originally Posted by pivoarch View Post
    Same here.
    UNTIL 2019.2
    The Recent Files "Home" page in 2019.2 works the way we've always wanted Recent Files to work.
    2019.2's Home page shows only the Central Files, and always makes a new Local
    wgfletch and tidalwave1 like this.
    July 7, 2017
    Hernando, MS
    492
    12:19 AM
    Same here.
    UNTIL 2019.2
    This. I had always had Recent Files disabled ever since it was introduced, until this latest version. Now I have it enabled on our machines.
  1. Replies: 0
    Last Post: August 30th, 2016, 09:15 PM
  2. Embedded door panel changed horizontal location when height parameter is changed
    By DavidLarson in forum Architecture - Family Creation
    Last Post: August 10th, 2015, 05:59 PM
  3. Building Coder: Document Version, GUID and Number of Saves
    Last Post: August 21st, 2014, 09:15 AM
  4. Replies: 0
    Last Post: November 8th, 2012, 05:15 AM
  5. Building Coder: Build Your Own Document Changed Event
    Last Post: February 29th, 2012, 09:15 AM
