Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Like Tree2Likes
Thread: Document has changed since last version?
  1.    #11
    Member PatrickGSR94's Avatar
    July 7, 2017
    Hernando, MS
    412
    03:40 PM
    Regardless of if you USE the Drive Letters, are they on your machine at all? IE: IS there a drive letter going to that server share, on your server? Or none at all?
    We have a domain logon script that maps drive letters for our active projects and archive projects, plus a "personal" folder for each domain user. But they are not used in Revit unless someone points to the mapped drive using the dropdown box at the top of the open/save dialog box. Which I never do, ever. And the 2 projects this happened on has not been worked on by anyone else in the office. I also have Places buttons on the left side that point to the UNC path of each server share. And likewise the reported Saved Path of every file in my Recent Files points to the UNC path for the project file.
  2.    #12
    July 7, 2017
    Hernando, MS
    412
    03:40 PM
    Also checked journals, the only time the mapped drive letter shows up is when I opened a family directly from Windows Explorer by double-clicking. There is nothing project file-related in the journals that have the mapped drive letter associated with them.
  3.    #13
    9,912
    03:40 PM
    Quote Originally Posted by PatrickGSR94 View Post
    So... I would REALLY look through the Journals and see if its using the Drive Letter.
    It actually *doesnt matter* "how you navigate" to the file from within Revit, if- outside of revit- the Drive Letters get used. Its some weird ambiguous logic that might be "however you navigated to that share last, outside of Revit." And yes, im absolutely serious.
    Ive seen it happen at firms where employees mapped drive letters themselves, even though they knew not to use them in Revit:
    If i opened windows explorer and navigated to the share correctly through UNC, then closed the Explorer window, and opened a file in Revit through File>Open>UNC, it would work fine.
    If i opened windows explorer and navigated to the share through the drive letter, then closed the Explorer window, and opened a file in Revit through File>Open>UNC, it would not work.
    Its a bit hideous. But my guess is you arent properly in the local file, and you are- in fact- writing over the central file on Sync.
  4.    #14
    July 7, 2017
    Hernando, MS
    412
    03:40 PM
    So it just happened again on the same project file this morning. It created a local file on my workstation as normal, and it's pointing to the central file on the server through the UNC path, as normal. I just checked the journal file for today and there are no mapped drive letter paths whatsoever.
    The SWC process still works normally, and Show History doesn't show anything out of the ordinary.
  1. Replies: 0
    Last Post: August 30th, 2016, 09:15 PM
  2. Embedded door panel changed horizontal location when height parameter is changed
    By DavidLarson in forum Architecture - Family Creation
    Last Post: August 10th, 2015, 05:59 PM
  3. Building Coder: Document Version, GUID and Number of Saves
    Last Post: August 21st, 2014, 09:15 AM
  4. Replies: 0
    Last Post: November 8th, 2012, 06:15 AM
  5. Building Coder: Build Your Own Document Changed Event
    Last Post: February 29th, 2012, 10:15 AM
