Results 1 to 4 of 4
Like Tree2Likes
  • 1 Post By DaveP
  • 1 Post By Zrinka
Thread: Wall and Floor join problem
    Junior Member Zrinka's Avatar
    February 25, 2017
    19
    06:21 AM
    How to join this? Please help
    Sent from my EML-L29 using Tapatalk
    February 25, 2017
    19
    06:21 AM
    In the meantime I managed to fix this
    Moderator DaveP's Avatar
    January 10, 2011
    St Paul, MN
    2,980
    12:21 AM
    Generally the way this Forum works is people post a question, and then the forum members are helpful to each other and post the solution so that others having the same problem can search for a solution.
    cganiere likes this.
    February 25, 2017
    19
    06:21 AM
    Well... Concrete layer of the wall wasn't inside the core boundary... Once i've put it inside the core boundary, it all joined correctly
  1. wall / floor join - edge of floor wrapping up past wall finish
    By alinamcconnochie in forum Architecture and General Revit Questions
    Last Post: July 6th, 2018, 10:22 PM
  2. Floor to wall join
    By byk3bep in forum Architecture and General Revit Questions
    Last Post: March 29th, 2015, 09:52 PM
  3. "Join" two floor slabs of different materials, without the line where they join?
    By kescr in forum Architecture and General Revit Questions
    Last Post: September 15th, 2014, 01:17 AM
  4. Wall join problem
    By Red in forum Architecture and General Revit Questions
    Last Post: February 19th, 2013, 05:08 PM
  5. Wall join problem
    By bobabc40 in forum Architecture and General Revit Questions
    Last Post: December 24th, 2012, 11:30 AM
