Results 1 to 5 of 5
Thread: Modelling Rolling Height Limit Plane
    Junior Member 411toaster's Avatar
    July 14, 2011
    Auckland, New Zealand
    35
    07:49 PM
    Hi all,
    At present to model the rolling height limit on sites we make a copy of the existing topography and copy it up by the height limit, then place this on a separate workset and use filters to make it a red dashed line and the topo transparent.
    Now we are getting into more detail we need to start cutting up the existing topography with building pads, but they automatically host themselves to the highest topo, that being the rolling height plane. Only way to stop this happening is to make the Rolling height limit topo a link so it is ignored.
    Is there a way to tell revit to host the building pad to the existing topo and ignore the rolling height limit copy with out making it a link? Just want to keep things a bit simpler for now. I'm guessing the answer is no, but worth a shot. When making a building pad does revit simply look for the first topo it comes across? or the order in which they are modelled?
    cheers,
    Charles
    Mr. Revit OpEd
    2,866
    11:49 PM
    Might consider creating a floor/roof based on the topo using something like Laura's dynamo script as a starting point? Instead of putting it at the same elevation, provide the offset that the height limit requires.
    July 7, 2011
    Rotterdam, Holland
    1,199
    08:49 AM
    Just something that I thought of, but when you place the second topo on a different phase, might that do the trick?
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,124
    02:49 AM
    As of 2018 (I think) you can host railings to a topo. Might be worth a shot.
    Senior Member Alex Page's Avatar
    December 13, 2010
    Wellington, New Zealand
    648
    06:49 PM
    Thats really fantastic for boundary sunlight access planes: https://www.caduceus.co.nz/sunlight-...in-revit-2018/ but not sure on how it would work for height limits....
    Ive always just linked them in...
  1. Wall Sweep along 3D path - Height to boundary plane
    By John_C in forum Architecture and General Revit Questions
    Last Post: September 26th, 2018, 08:44 AM
  2. Roof with one plane on a different plate height **complex roof system**
    By lparnell583 in forum Architecture and General Revit Questions
    Last Post: December 7th, 2016, 09:42 PM
  3. Replies: 0
    Last Post: November 27th, 2016, 07:45 AM
  4. Height Param: Ref Level v Ref Plane?
    By snodaisy in forum Architecture - Family Creation
    Last Post: September 22nd, 2015, 06:25 PM
  5. Replies: 0
    Last Post: July 30th, 2013, 11:45 AM
Tags for this Thread
