Page 1 of 2 12 LastLast
Results 1 to 10 of 15
Like Tree1Likes
Thread: 2d linework order
  1.    #1
    July 3, 2018
    10
    08:26 PM
    2d linework order
    Hi all,
    Please see attached. In plan view i have chairs arranged around a table, the chairs should disappear under the table top as arranged.
    However the linework is still visible with the chairs over the table!
    Chair and table are 3d modeled - no elements visible in plan and relying on symbolic lines and masking areas to provide plan view.
    How do i make the chairs disappear beneath the table top?
    Many thanks!
    Dave
  2.    #2
    June 21, 2012
    Tours, France
    896
    09:26 PM
    Can you upload those to take a look?
  3.    #3
    July 3, 2018
    10
    08:26 PM
    Hi , thanks for your help.
    Chair is too big to attach here is table.
    Link to chair
    https://www.hermanmiller.com/content...air_rfa_3D.zip
    Attached Files Attached Files
  4.    #4
    Senior Member kamranmirza's Avatar
    January 12, 2011
    London, UK
    515
    08:26 PM
    Quote Originally Posted by homerdude View Post
    . . . How do i make the chairs disappear beneath the table top? . . .
    It might be that the chairs are detail elements with a masking region in the chair family [with the model elements visibility unticked] and they are masking the model element table. The way to check would be to check in the Ref.Level view of the chair family.
  5.    #5
    June 21, 2012
    Tours, France
    896
    09:26 PM
    ...Hi , thanks for your help...
    Hello, I've took a look into your families and the problem is very easy to solve actually, you just need to open your chair family and in a 3D view you need to select the geometry and by hitting the Visibility replacements (Sorry if this is not the exact term, but my Revit is in French) you just select the visibility parameters dialog box and check the box called Plan/Ceiling Plan (See images) this will active the geometry to show in plans, let me know if this works for you, regards
    and the problem was due to: "the chairs are detail elements with a masking region in the chair family [with the model elements visibility unticked] and they are masking the model element table". as @ Kamran Mirza already tell you in his post!
    Attached Thumbnails Attached Thumbnails 2d linework order-chairs.jpg   2d linework order-visual.jpg
  6.    #6
    Moderator DaveP's Avatar
    January 10, 2011
    St Paul, MN
    2,898
    03:26 PM
    Issues like this really make me wonder if its time to give up on Symbolic Lines.
    Do they really serve much purpose anymore?
    There was a time and place for Symbolic Linework when we had slower processors and 4 Gig of memory, but isn't any machine capable of running Revit capable of doing the 3D hidden line calculations these days?
  7.    #7
    9,912
    03:26 PM
    I gave them up in 2009. There is no place for them anymore, and hasnt been for a long time.
    Back then the issue was the wimpy graphics cards, not the processors.
    Mengelmn likes this.
  8.    #8
    July 3, 2018
    10
    08:26 PM
    Thanks Andres and everyone for your help!
    I did as you said and it worked. I learned it that i have to use symbolic lines and masking regions and they would stack in order based on their position with the model (hence table would mask chairs).
    Just so i understand this correctly:
    • There is no reason to use symbolic lines and masking reasons anymore - it was just a performance thing and now processors are up to job.
    • Use the 3d geometry whenever possible.
    • Use symbolics v sparingly as no way to control stack order.
    Regards
    Dave
  9.    #9
    July 10, 2015
    Boise, Idaho
    611
    02:26 PM
    Even in cabinets?
  10.    #10
    December 21, 2010
    Phoenix, AZ
    2,514
    01:26 PM
    Yes, even in cabinets.
  1. Linework issue
    By tjbota in forum Architecture and General Revit Questions
    Last Post: August 8th, 2014, 07:41 PM
  2. Annotation Linework
    By Alfienoakes in forum Architecture - Family Creation
    Last Post: June 4th, 2013, 03:55 PM
  3. Draw order / Update order
    By anthonyB in forum Architecture and General Revit Questions
    Last Post: March 22nd, 2013, 02:57 AM
  4. Linework tool
    By dzatto in forum Tutorials, Tips & Tricks
    Last Post: July 30th, 2011, 01:15 AM
  5. Phases and Linework
    By redmonki in forum Architecture and General Revit Questions
    Last Post: April 4th, 2011, 06:05 PM
