Hi, i have a multistory stair from someone else...it's spanning from basement to level 2. I just want to keep the stair for Level1 to Level2, but when i try disconnect levels, only level 2 level is showing. If i disconnect it from Level2, the portion that I want will get delete.
If I tried to connect levels, somehow I cannot pick on level 1, only can pick level 2.
Any way to convert it back to normal stair or edit it?
Thanks in advance.
Sent from my SM-N950F using Tapatalk
