Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Like Tree14Likes
Thread: Floating Scale Bar
  1.    #1
    August 2, 2018
    20
    05:43 PM
    Floating Scale Bar
    I am wondering what it would take to make a scale bar that auto scales when you zoom in and out and is floating in your work space. ideally i would be able to set it at 4' and i would have a constant visual indicator of what 4' is no matter if i zoom out and pan. haven't found anything through looking around online so figure I would throw it out there and see if anyone knows something on it.
    thanks
  2.    #2
    Senior Member kamranmirza's Avatar
    January 12, 2011
    London, UK
    515
    12:43 AM
    You'd just be making a model element [i.e. in 3D] with the distances/text made in model text. You could make it as a family, perhaps generic ? And set it so you only see it in plan views and not others. You could also make it 3-dimensional and have sides going up in the X and Y directions too so it would appear in sections and elevations, but you'd have to locate it below Level-0 to have it in the right place in views.
    We in the UK are only compelled to place scale bars on planning application drawings and for that we've got an annotation family that fits into our view title when required.
    The 3-D scale bar sounds fun and may even be less aggro than manually placing scale bars for all views on sheets.
    I'll leave it to you to prove it. Good luck !
  3.    #3
    January 12, 2011
    London, UK
    515
    12:43 AM
    By far this is the best solution that I've seen so far . . .
    https://knowledge.autodesk.com/suppo...21843d583.html
    Even though it's not 3D but it accepts the fact you may have drawings with 2 scales on one sheet.
  4.    #4
    January 12, 2011
    London, UK
    515
    12:43 AM
    And don't forget some history of scale bars in this forum:
    https://www.revitforum.org/architect...ale-bar-3.html
  5.    #5
    August 2, 2018
    20
    05:43 PM
    the closest example i can find is in Trimble Field Link. i attached some pics showing their scale bar.
    Attached Thumbnails Attached Thumbnails Floating Scale Bar-3-12-2019-7-53-50-am.png   Floating Scale Bar-3-12-2019-7-54-04-am.png
  6.    #6
    Moderator DaveP's Avatar
    January 10, 2011
    St Paul, MN
    2,889
    07:43 PM
    Just curious what's the point of that?
    Can't you tell the "scale" of your model by a wall or a door just as easily?
    Mengelmn likes this.
  7.    #7
    August 2, 2018
    20
    05:43 PM
    The door wouldnt "float" as you pan around. so you would have to drag it around as you pan or keep going back to it
  8.    #8
    January 10, 2011
    St Paul, MN
    2,889
    07:43 PM
    Well, we typically have more than one door in our projects.
  9.    #9
    August 2, 2018
    20
    05:43 PM
    yes but most of my work is in parking garages and ground works so very rarely is there a door visible. i could take a bunch of doors and scatter them throughout the floor plan but figured i would see if anyone else has thought of this or what people think of it.
  10.    #10
    January 10, 2011
    St Paul, MN
    2,889
    07:43 PM
    Or parking spaces?
  1. Floating Scale Bar
    By Blake Bunn in forum MEP - General
    Last Post: March 11th, 2019, 10:51 PM
  2. Dimensional Accuracy & Floating Point display rounding etc....
    By BLothian in forum Architecture and General Revit Questions
    Last Post: April 5th, 2018, 04:29 PM
  3. Revit Type Selector Floating Toolbar
    By Joshua Kohl in forum Architecture and General Revit Questions
    Last Post: September 11th, 2017, 12:50 PM
  4. Floating Geometry when nesting walls in a curtain wall
    By itisntmakingsense in forum Architecture and General Revit Questions
    Last Post: December 13th, 2016, 01:50 PM
  5. Floating Type Selector????
    By jcoe in forum Architecture and General Revit Questions
    Last Post: November 26th, 2014, 05:37 PM
