Results 1 to 2 of 2
Thread: Certain tags in a linked model show questions marks when VG set to "By Linked View"
  1.    #1
    August 17, 2015
    3
    04:42 PM
    We have a Bim360 Design Collab. project with a specialty Equipment tag that shows a shared parameter called "AltID" in our Equipment plans.
    When this model is linked into other models, and set to show "By Linked View" the tags show question marks.
    from our file, these tags show as question marks in consultants files.
    Is there a solution for this?
    Attached Thumbnails Attached Thumbnails Certain tags in a linked model show questions marks when VG set to "By Linked View"-aa9b1563.png
  2.    #2
    Coeur d Alene, ID
    4,640
    01:42 PM
    Your consultants need to have that same parameter loaded into their tags and project.
  1. Possible to copy "View Types" from linked model
    By Jozi in forum Architecture and General Revit Questions
    Last Post: October 11th, 2018, 08:11 AM
  2. Linking models into a "central" model file, linked views and view templates
    By DesignApparatus in forum Architecture and General Revit Questions
    Last Post: May 18th, 2018, 05:39 AM
  3. linked room tags wont "stick"
    By waikikigirl in forum MEP - General
    Last Post: August 23rd, 2016, 02:02 PM
  4. Linked CAD files do not display, don't show up in "Manage Links" menu
    By truthjusticeUSAway in forum MEP - General
    Last Post: October 12th, 2013, 11:25 PM
  5. Can't control the "By linked view" of linked model
    By alexo4141 in forum Architecture and General Revit Questions
    Last Post: November 22nd, 2012, 09:44 PM
