Results 1 to 4 of 4
Thread: Can't view walls on second floor?
  1.    #1
    March 11, 2019
    2
    08:13 PM
    I am unable to view the walls constructed on the ground floor on the second floor plans. I have the upper limits of the walls selected correctly to the second floor level.
    Is anyone able to help, thanks?
    I have attached some screenshots
    Attached Thumbnails Attached Thumbnails Can't view walls on second floor?-2019-03-11.png   Can't view walls on second floor?-2019-03-11-3-.png
  2.    #2
    Coeur d Alene, ID
    4,640
    01:13 PM
    Turn on Underlay... Also, your first picture has the floor plan on Level 0...what is on Level 1?
  3.    #3
    March 11, 2019
    2
    08:13 PM
    Thanks for the reply, I have another floor on Level 1. Level 2 is going to be a loft conversion.
    Shouldn't I be able to see the walls anyway if this is at roof level anyway? As underlay will just replicate the floor below?
  4.    #4
    Coeur d Alene, ID
    4,640
    01:13 PM
    Only if your view depth is to the floor below and there isn't a floor or ceiling in the way.
  1. Replies: 1
    Last Post: January 31st, 2019, 03:59 AM
  2. Floor highlight in floor plan view not showing
    By m b in forum Architecture and General Revit Questions
    Last Post: September 5th, 2018, 01:30 PM
  3. Walls below floor are visible in plumbing view
    By Famous87 in forum MEP - General
    Last Post: September 16th, 2016, 12:28 PM
  4. 2nd Floor Walls Shorter than 1st Floor
    By fl0j0m0j0 in forum Architecture and General Revit Questions
    Last Post: April 28th, 2015, 07:27 PM
  5. Why is glass projecting through the walls and floor in 3D view?
    By commando17 in forum Architecture and General Revit Questions
    Last Post: April 13th, 2014, 03:39 PM
