Results 1 to 10 of 10
Like Tree1Likes
  • 1 Post By NoamRo
Thread: 3D Visualization
  1.    #1
    October 16, 2016
    394
    02:11 AM
    3D Visualization
    Hello all,
    In our office we have some 3D projects in Revit, ArchiCAD, AutoCAD and Allplan.
    We would like to have a way to present the 3D models in our clients outside of the office (that means that we will not have access in our program licences).
    What software do you use in this case?
    We would like also to have the ability to navigate into the 3D model..
    Thank you in advance!
  2.    #2
    February 11, 2019
    6
    03:11 AM
    We use Enscape, it has support for Revit and ArchiCAD, I don't think it supports AutoCAD or Allplan.
    It works very well for our uses, and you can easily export a .exe file that can be sent or displayed without having the program on the computer.
    There are several alternatives, so far I've found Enscape to be the easiest to use, and more than enough visually speaking to display and navigate around the model.
    tiangtiang likes this.
  3.    #3
    October 16, 2016
    394
    02:11 AM
    Quote Originally Posted by NoamRo View Post
    We have also Enscape. I exported an.exe format. I tried to open it in another computer but I had an error message that the graphics are not supported.
  4.    #4
    Coeur d Alene, ID
    4,635
    06:11 PM
    Prefer Enscape as you get realtime updates if you modify the model in Revit, no need to export the model. Unfortunately it will only work with Revit and ArchiCAD. If you have SketchUp or Rhino it will work for that too if you can export your Autocad and Allplan to those. Another option is Lumion which you have to export your model to a certain format or using an add-in. I'm not familiar enough with AllPlan to know if it will work.
  5.    #5
    Coeur d Alene, ID
    4,635
    06:11 PM
    Quote Originally Posted by MARIA1993 View Post
    Unsupported video card...was it a machine with an intel HD graphics card by chance?
  6.    #6
    Forum Addict Robin Deurloo's Avatar
    July 7, 2011
    Rotterdam, Holland
    1,093
    02:11 AM
    Yep Intel GPU will not work with the .exe file. It will work when you export to an online version, but depending on the size of your project that will be slooooow and not as pretty as the offline .exe file.
  7.    #7
    March 11, 2019
    4
    06:11 PM
    Another Enscape user here; have not found anything better as of yet and the built-in VR capabilities are nice. It will be unlikely you will find this type of tool with cross-platform support of all the above mentioned products albeit Enscape comes close offering plug-ins for at least two if not three of those programs. And yes, you need a fairly competent graphics card to run Enscape exports.
  8.    #8
    October 16, 2016
    394
    02:11 AM
    Thank you for your answers..
    As I checked you can not create sections directly in Enscape. You can only navigate through the building, right?
    In order to create sections you need firstly to create them in revit and after export in Enscape.
    What graphic cards requirements do you have?
  9.    #9
    November 2, 2011
    Slaithwaite ("Sla wit"), W Yorks, UK
    231
    01:11 AM
    You could export the models as IFC and there are plenty of free IFC viewers out there to choose from.
  10.    #10
    Coeur d Alene, ID
    4,635
    06:11 PM
    About 90% of us have GTX 1080 ti's...getting some new machines in soon and hoping they have RTX 2080's.
    Not on the list for a new machine...there are a few folk that have older machines than I do. One of the architects is still running a i7-2600k and a GTX 760 ti and I have a i7-3820.
  1. Visualization issue [ITA-ENG]
    By Dario in forum Architecture and General Revit Questions
    Last Post: March 11th, 2016, 07:43 PM
  2. 3d visualization
    By Nikolas32 in forum Architecture - Family Creation
    Last Post: February 29th, 2016, 02:24 PM
  3. About vpn and visualization between different disciplines
    By Redolat in forum Architecture and General Revit Questions
    Last Post: July 3rd, 2015, 08:05 AM
  4. Visualization and post production
    By mona miller in forum Architecture and General Revit Questions
    Last Post: July 6th, 2014, 09:46 PM
  5. Mechanical Ducts for Visualization only
    By mfrietze in forum Architecture - Family Creation
    Last Post: January 11th, 2012, 11:00 PM
