Results 1 to 6 of 6
Like Tree1Likes
  • 1 Post By Twiceroadsfool
Thread: Anno Label showing only first few letters of type mark?
    April 12, 2015
    63
    05:43 AM
    Hi. I have many different type marks for existing walls in my project, W-EXTG_1, W-EXTG_2 etc, is it possible to have a wall type tag to tag all the existing walls as
    W-EXTG only? Coz in my wall schedules, I only want to show them as existing wall, and only new walls will need to show the various types.
    But if I change the wall type mark, I will get warning to say elements have duplicate type mark. Is there a way to just tag these extg wall to show only first 6 letters in the type mark?
    Thanks in advance.
    Sent from my SM-N950F using Tapatalk
    February 23, 2018
    Port Elizabeth, South Africa
    72
    05:43 AM
    Create a wall schedule and create a filter for existing walls (contains EXTG). Set it to not individualise the walls and then change the type mark for all of them.
    April 12, 2015
    63
    05:43 AM
    But that will result in the warning, different walls having duplicate type mark.
    Gold Coast
    2,619
    03:43 PM
    Quote Originally Posted by tiangtiang View Post
    You're pretty much going to have to live with the duplicate type mark warnings, unless you use a custom parameter.
    Member PatrickGSR94's Avatar
    July 7, 2017
    Hernando, MS
    492
    12:43 AM
    It's not a big deal to have duplicate type marks. All our doors are that way because we use type marks, and each door size type will have the same type mark for that particular style of door (flush, half glass etc.).
    10,186
    12:43 AM
    I would switch to a Shared Parameter instead of Type Mark, regardless. Has lots of benefits. Not in this case (other than the warning going away), but in many others.
    GMcDowellJr likes this.
  1. How to change the text colour of bullet point type upercase letters in Revit?
    By Ramage in forum Architecture and General Revit Questions
    Last Post: March 30th, 2018, 09:54 AM
  2. Type Mark (and Material Mark) linked to Sheet Number or Name
    By tjgreatrex in forum Architecture and General Revit Questions
    Last Post: September 11th, 2017, 04:20 PM
  3. Pushing Type Name to Type Mark
    By cellophane in forum Dynamo BIM
    Last Post: October 8th, 2015, 03:39 AM
  4. Label In Family Comes up as a question mark
    By mikey1073 in forum Architecture and General Revit Questions
    Last Post: October 11th, 2012, 01:18 PM
  5. Revit OpEd: Dept. of Flashback - Mark and Type Mark
    By Blog Fetcher in forum Blog Feeds
    Last Post: June 21st, 2011, 07:00 AM
