Results 1 to 8 of 8
Thread: Adding Filters in both V/G Overrides AND in ViewTemplate
    February 11, 2019
    9
    08:31 AM
    Question Adding Filters in both V/G Overrides AND in ViewTemplate
    Hi All,
    I'm working on a new workflow, which will require a number of different filters on each view. Is there a way to have both ViewTemplate based filters, and also view-specific filters?
    So far, I've seen that if a ViewTemplate is set, the option for adding view-specific filters is greyed out. Does anyone know a way around this?
    Thanks in advance!
    Moderator DaveP's Avatar
    January 10, 2011
    St Paul, MN
    2,980
    12:31 AM
    Nope.
    You can uncheck Filtering in your View Template, but then it is ONLY controlled by the individual View Overrides.
    Once you use a parameter in a View Template it is ONLY controlled by the VT.
    February 11, 2019
    9
    08:31 AM
    Thanks for your input Dave,
    I feared that would be the pro's answer.
    Thanks again!
    Member pivoarch's Avatar
    March 16, 2011
    Princeton, NJ
    306
    01:31 AM
    If you could describe what you are trying to achieve with filters in your different views we might be able to help you develop a process that works without all the gymnastics.
    February 11, 2019
    9
    08:31 AM
    I'm doing some fairly advanced view creation using dynamo.
    Basically, I need a set of section views for each wall in the building, and each view in the set needs to show a different layer, have different category overrides, etc.
    I have a set of view templates which I'm automatically assigning to each new view, and I'm using filters in some of them (to show/hide parts of the wall based on material).
    I also have a unique filter that is generated for each wall, with a "Wall ID" shared parameter I have created.
    This is used to only show the relevant elements in each view. For example - a light switch with a Wall ID value of 005, will only be displayed in a view with the filter showing elements with the value 005 in their Wall ID field.
    What I would like to have is a view template, with all the relevant filters, overrides, and other settings, and also to add an individual, per-view filter of the Wall ID parameter.
    Sorry for the wall of text, hope I made some sense in my explanation.
    Thanks!
    10,186
    12:31 AM
    Technically, yes.
    1. Use Dynamo to create the view, applying the default View Template.
    2. Have Dynamo then unapply the view template (use Passthrough to make sure it happens after)
    3. Have Dynamo then add the required Filter in (use Passthrough to make sure it happens after)
    But the View Template will have no connection to the views once you are done.
    February 11, 2019
    9
    08:31 AM
    Hi Aaron,
    I tried to go that way but found that I need to keep control of the View Templates and not lose their influence..
    For now, my solution is setting all the filters using Dynamo, both the independent, per-wall filter and the filters that should be part of the View Templates.
    Thanks for your input everyone, I think I'll stop pursuing this direction as it appears to be a dead-end.
    Thank you!
    Mr. Revit OpEd
    2,882
    10:31 PM
    Assign a View Template afterward that does not Include Filters but everything else. Use Dynamo to assign the Filters, update them as required ongoing.
  1. Replies: 17
    Last Post: June 19th, 2017, 06:12 PM
  2. Replies: 6
    Last Post: June 29th, 2016, 07:33 PM
  3. Extract just one viewtemplate from a project.
    By JelmerEekman in forum Architecture and General Revit Questions
    Last Post: June 22nd, 2016, 04:50 PM
  4. Filters of VG overrides
    By domsib in forum MEP - General
    Last Post: July 11th, 2013, 01:03 AM
  5. 3D dwf with phases overrides
    By redmonki in forum Architecture and General Revit Questions
    Last Post: March 14th, 2012, 09:14 AM
