Results 1 to 10 of 10
Like Tree14Likes
  • 1 Post By Andres Franco
  • 1 Post By mjajansen
  • 7 Post By Alfredo Medina
  • 1 Post By tiangtiang
  • 2 Post By Twiceroadsfool
  • 2 Post By MPwuzhere
Thread: Y-shaped Ramp
    April 12, 2015
    63
    09:12 AM
    Y-shaped Ramp
    Hi.
    1) May I know if there's any way to do a y-shaped ramp in revit?
    2) if both side have diff gradient. Ie. The blue ramp will end at different level comparing to the yellow one.
    Note the red line is a sloping line.
    Sent from my SM-N950F using Tapatalk
    June 21, 2012
    Tours, France
    940
    11:12 AM
    Quote Originally Posted by tiangtiang View Post
    Hi.
    No by using the OOTB Ramp tool I guess, Maybe DYNAMO can achieve this!
    One can imagine doing a double sloped ramp maybe by using a floor with the modify edges active, but I guess it will be complex to do!
    tiangtiang likes this.
    Member mjajansen's Avatar
    December 25, 2011
    The Netherlands
    180
    09:12 AM
    The floor tool can make this.
    Orlando, FL, USA
    3,093
    05:12 AM
    One way to do it is this:
    1) In an generic model adaptive template, draw two splines of three points (a and b). Then draw spline "c" of three points hosted on "b". Then draw reference lines "d" and "e". Select "a" and "b" and do Create Form. Select "c", "d", and "e", and do Create Form. Add and Offset value to the two points at the end of the form made with "a" and "b", that determine the high point of the ramp, to create the slope. Load into Project.
    2) Massing and Site, Roof by Face, select the surface. Add parapets as needed, as sweeps along the curves.
    Attached Thumbnails Attached Thumbnails Y-shaped Ramp-2019-03-05_11-25-03.jpg   Y-shaped Ramp-2019-03-05_11-22-36.jpg
    Last edited by Alfredo Medina; March 5th, 2019 at 03:42 PM. Reason: added info about creating the slope.
    April 12, 2015
    63
    09:12 AM
    Thank u so much for taking your valuable time to show the method.
    I will try it out! I am not very familiar with adaptive family. But since you already shown that it'll works, at least I know it can be done if I try hard enough.
    d.stairmand likes this.
    10,100
    04:12 AM
    I would go with shape edited roofs or floors. If they have a coincident edge, the shape editing points will even snap to each other as you raise and lower them.
    Andres Franco and d.stairmand like this.
    June 21, 2012
    Tours, France
    940
    11:12 AM
    Amazing as always @Alfredo!! thank you for sharing this workaround!! Regards
    June 21, 2012
    Tours, France
    940
    11:12 AM
    ...shape edited roofs or floors. If they have a coincident edge, the shape editing points will even snap to each other....
    Yes that was my initial thought, never considered the workaround with the roofs!!
    Senior Member kamranmirza's Avatar
    January 12, 2011
    London, UK
    534
    10:12 AM
    Normally curved ramps have a camber sloping towards the centre of the curve, but I guess Alfredo's method will allow for that too.
    Example below of super-elevation calculation software screenshot [spiral ramp example NOT SHOWN]:
    Image source: Compute & Apply Superelevation
    Coeur d Alene, ID
    4,737
    02:12 AM
    Then we find out OP has Revit LT....
  1. How do I create a Y shaped column?
    By dylanrevitq in forum Architecture and General Revit Questions
    Last Post: January 29th, 2018, 07:35 PM
  2. Ring shaped Lighting Family
    By BIM_grl in forum MEP - Family Creation
    Last Post: December 8th, 2017, 09:38 AM
  3. L-Shaped Shed roof - Revit
    By malou_denum in forum Architecture and General Revit Questions
    Last Post: May 18th, 2016, 05:27 AM
  4. Can this be done? (L-shaped retaining wall with sloping base/Tilted L-shaped wall)
    By Glenn Arne in forum Architecture and General Revit Questions
    Last Post: January 27th, 2016, 10:58 PM
  5. Irregular shaped viewport.
    By Helga in forum Architecture and General Revit Questions
    Last Post: December 29th, 2015, 08:42 AM
