Page 4 of 4 FirstFirst 1234
Results 31 to 38 of 38
Like Tree17Likes
Thread: Not seeing synchronize (SWC) reminders
  1.    #31
    Senior Member Charles Karl's Avatar
    December 6, 2011
    Fairbanks, Alaska
    973
    04:28 PM
    Whole lot more complexity. Plus who says you always sync on a schedule? Like I said, if I finished something big and important, I sync. 8 user pileups don't happen as much if they sync often and the syncs are faster.
    The issue is the 20-30 minute wait when multiple people sync at the same time. We discussed a method of syncing every hour which meant that there was a sync at least every 15 minutes staggard, and if done correctly, only resulted in a 5 minute sync time on this particular project. What becomes difficult is not knowing if a sync is completed before it becomes the next person's time to sync.
  2.    #32
    Mr. Revit OpEd
    2,830
    05:28 PM
    A few years ago a large team I worked with resorted to using IM (Skype) to announce “SwC next”, before anyone sync’d they checked the queue...a habit they had to nurture. That’s how they dealt with the stacking up of planes on approach.
    Charles Karl likes this.
  3.    #33
    Member PatrickGSR94's Avatar
    July 7, 2017
    Hernando, MS
    408
    07:28 PM
    I changed the SWC reminder to 30 minutes yesterday. This morning I saw the SWC reminder finally. So I checked EVERY journal I have (a month's worth) for the text string used in the dialog box, and sure enough it doesn't exist in any journal in the past month except today. Weird.
  4.    #34
    9,907
    07:28 PM
    That text string isnt even remotely close to what appears in the journal when it reminds you to Sync with Central. Naturally, that search wouldnt turn up any results. Why dont you just post one?
  5.    #35
    Mr. Revit OpEd
    2,830
    05:28 PM
    Should be more like this...(see image)
    Attached Thumbnails Attached Thumbnails Not seeing synchronize (SWC) reminders-reminder.jpg
    Twiceroadsfool likes this.
  6.    #36
    July 7, 2017
    Hernando, MS
    408
    07:28 PM
    Quote Originally Posted by Steve_Stafford View Post
    Steve that's the local save reminder. The SWC looks like this, and Aaron as you'll see, yes it does contain the text "Synchronize with Central". However yesterday when I checked all my past journals I searched for the text string "contains changes". All past journals had no such text, except for yesterday, and now today's journal file.
    Attached Thumbnails Attached Thumbnails Not seeing synchronize (SWC) reminders-swc.jpg
    cellophane likes this.
  7.    #37
    9,907
    07:28 PM
    Ahh, good call! I must have looked for the Save reminder by accident!
  8.    #38
    July 7, 2017
    Hernando, MS
    408
    07:28 PM
    So something is still going on with this issue. Even though I have SWC reminders set to 30 minutes, I saw zero reminders on Monday, and only one reminder yesterday (Tuesday) at ~4 PM.
  1. Why doesn't RVT have the ability to synchronize grids between views?
    By erratic in forum Architecture and General Revit Questions
    Last Post: November 30th, 2018, 07:54 PM
  2. Replies: 0
    Last Post: December 7th, 2017, 06:15 PM
  3. Revit OpEd: Did you Load a Family - Synchronize NOW
    Last Post: April 8th, 2016, 12:15 AM
  4. Building Coder: Synchronize with Central
    Last Post: January 25th, 2012, 10:16 AM
