Page 1 of 2 12 LastLast
Results 1 to 10 of 14
Like Tree3Likes
Thread: Rooms Not Listed in Furniture Schedule Filter
    November 2, 2011
    Slaithwaite ("Sla wit"), W Yorks, UK
    240
    07:38 PM
    We have a need to schedule furniture and equipment in rooms where the equipment is in a linked file. The rooms are in the host file and the new construction is in the host file, but the existing construction is in a linked file. We are using Revit 2015.
    This works fine where the rooms are bounded by walls in the host file, and we can filter the furniture schedule by the room number. However, where rooms are bounded by walls in the linked file, the room number does not appear in the drop down list in the filter dialog.
    If we create a room schedule (not a furniture schedule) all of the rooms are listed. It is only in the furniture schedule where they are not all shown.
    We have tried enclosing the affected rooms with room separation lines and this has no affect. We also tried using walls to split the rooms down, creating new rooms - none were listed either. It is not a phasing or design options issue. It has me baffled! Any ideas..?
    Senior Member
    December 16, 2010
    849
    04:38 AM
    Did you click on the link file then go to edit properties and tick "room bounding"?
    Attached Thumbnails Attached Thumbnails Rooms Not Listed in Furniture Schedule Filter-rooms.jpg
    Senior Member kamranmirza's Avatar
    January 12, 2011
    London, UK
    534
    07:38 PM
    And ticked the 'include elements links' in the furniture schedule ? Just saying, its sometimes the things right in front of you that one can't see.
    Karalon10 likes this.
    Senior Member
    December 16, 2010
    849
    04:38 AM
    yep that was my next question on the checklist
    November 2, 2011
    240
    07:38 PM
    Yes to both of the above - it is only a handful of rooms in the project that are affected, most are working just fine. I've also checked that all of the furniture elements in the linked model are in the same phase and same workset, and that the room location points for the families are within the room extents.
    If we add furniture elements in the host model to one of the problem rooms, then then these ARE scheduled OK. I've copied an element in the linked model from another room (where it was scheduling OK) to one of the affected rooms and it does not schedule... Crazy!
    September 19, 2017
    Seattle, WA
    37
    11:38 AM
    Check if the affected rooms are part of a design option. I know I've had trouble transferring data from rooms to spaces in that instance. It might be a similar issue.
    November 2, 2011
    240
    07:38 PM
    Quote Originally Posted by Robert Roffe View Post
    Yep, we checked that too. Everything is Main Model and Workset1.
    February 29, 2012
    63
    01:38 PM
    Perhaps I'm not reading this correctly, but if the goal is: I want to report on the room name of furniture/equipment and the rooms are in a different file, then the answer is that this is a known issue. Revit does not do that. Revit will report on all of the furniture found in both the host and the linked, and can report on all the rooms found within both files, but cannot properly report the room data for furniture/equipment when they are not within the same file as the rooms. Adding spaces might help.
    Let me know if I've misunderstood or if anyone else knows differently. I wrote a Help topic on this topic a while back when we allowed BIMLink to access that linked file spatial data: https://ideatesoftware.com/support/h...-and-room-data
    kamranmirza likes this.
    January 12, 2011
    London, UK
    534
    07:38 PM
    Quote Originally Posted by GlynnisPatterson View Post
    I want to report on the room name of furniture/equipment and the rooms are in a different file, then the answer is that . . . Revit does not do that.
    Revit will report on all of the furniture found in both the host and the linked, and can report on all the rooms found within both files, but cannot properly report the room data for furniture/equipment when they are not within the same file as the rooms . . .https://ideatesoftware.com/support/h...-and-room-data
    Wow. Good to know. Thanks.
    November 2, 2011
    240
    07:38 PM
    Good to know, indeed!
  1. Filter rooms by having or not parameters value
    By Aida Siala in forum Dynamo BIM
    Last Post: November 25th, 2017, 09:24 AM
  2. Furniture Schedule & Multiple Rooms
    By waders in forum Architecture and General Revit Questions
    Last Post: May 27th, 2016, 05:51 PM
  3. Rooms, Furniture, Move Management Plans
    By The Dropper in forum Architecture and General Revit Questions
    Last Post: October 27th, 2014, 02:37 PM
  4. Furniture Schedule Help
    By DanDr in forum Architecture and General Revit Questions
    Last Post: September 5th, 2012, 03:40 PM
  5. furniture schedule and phasing
    By LAbraham in forum Architecture and General Revit Questions
    Last Post: December 5th, 2011, 10:37 PM
