Results 1 to 4 of 4
Like Tree1Likes
  • 1 Post By GMcDowellJr
Thread: Room Bounding Check Box
    YF7
    YF7 is offline
    November 26, 2018
    4
    11:54 AM
    Can someone explain why do I need to check the room bounding box in the properties palette after linking a Rvt model? Thanks!
    December 21, 2010
    Phoenix, AZ
    2,642
    12:54 PM
    to save processing time in case you don't want it room bounding
    YF7 likes this.
    YF7
    YF7 is offline
    November 26, 2018
    4
    11:54 AM
    Thanks!
    Moderator DaveP's Avatar
    January 10, 2011
    St Paul, MN
    3,020
    02:54 PM
    Yup.
    It may not make a lot of sense if all you link in is other Architectural models, but imagine if the default was the other way 'round, and your HVAC or Plumbing model started defining Room Boundaries. Even Structural may not be wanted.
  1. Room Bounding?
    Last Post: August 17th, 2017, 05:00 PM
  2. Room tag not bounding to extent of room
    By aaronsmith0707 in forum Architecture and General Revit Questions
    Last Post: April 11th, 2017, 07:41 PM
  3. Is there a way to make a railing room bounding
    By karpov005 in forum Architecture and General Revit Questions
    Last Post: January 29th, 2016, 04:42 PM
  4. Room Bounding Check box for Linked files NOT working
    By emack in forum Architecture and General Revit Questions
    Last Post: November 18th, 2013, 12:30 PM
  5. Room bounding walls & and room separators. Rooms have no boundaries?
    By doni49 in forum Architecture and General Revit Questions
    Last Post: September 26th, 2013, 07:53 PM
