Results 1 to 10 of 10
Like Tree1Likes
  • 1 Post By Alfredo Medina
Thread: Combined Parameter - Filtering & Sorting
    Member MartinGT's Avatar
    August 17, 2011
    UK
    273
    02:17 PM
    Is it possible to filter and sort by combined parameters in 2019?
    Orlando, FL, USA
    3,088
    10:17 AM
    No, not possible.
    August 17, 2011
    UK
    273
    02:17 PM
    No, not possible.
    Back to the drawing board then! I have filters across a couple of different categories and a multi cat schedule doesnt fully do what I want either
    December 21, 2010
    Phoenix, AZ
    2,556
    07:17 AM
    You could use Dynamo to combine them into a new parameter.
    August 17, 2011
    UK
    273
    02:17 PM
    Quote Originally Posted by GMcDowellJr View Post
    I shall give that a whirl.
    August 17, 2011
    UK
    273
    02:17 PM
    Just to point out the reason I ask this.
    I have several models linked into a site model and some are copied. Have changed the Identity Name of the model to be the plot number. I wanted this plot number in my schedule. The only way I can schedule this is using a 'RVT Links' Schedule.
    I was initially going to use schedules side by side on a sheet. However I have no way of sorting the foundation schedule to suit the RVT Links one. I cannot put in an instance parameter as the parameter remains read only.
    Would this work if I create a new parameter using Dynamo?
    Orlando, FL, USA
    3,088
    10:17 AM
    Quote Originally Posted by MartinGT View Post
    ...The only way I can schedule this is using a 'RVT Links' Schedule. ...
    In the structural foundation schedule, check "include elements in links". Then from the "Select available fields from" select "RVT Links:Name". Now you can sort and filter the schedule by the name of the link. And that name can be changed, not in the schedule but selecting the link in the view.
    kamranmirza likes this.
    August 17, 2011
    UK
    273
    02:17 PM
    Alfredo, I could kiss you.
    I did have the box ticked, however I didnt click on the drop down where it says "Select available fields from"
    Thanks, you're a star
    Orlando, FL, USA
    3,088
    10:17 AM
    Haha, no, thanks, your gratitude is enough. Haha...
    Senior Member kamranmirza's Avatar
    January 12, 2011
    London, UK
    529
    03:17 PM
    Wow, thanks for that. Still got lots to learn !
  1. Replies: 0
    Last Post: June 1st, 2018, 04:15 PM
  2. Combined Parameter Units
    By GMcDowellJr in forum Architecture and General Revit Questions
    Last Post: April 17th, 2018, 01:19 AM
  3. filtering away nested families without filtering away their parent families
    By jnoordzij in forum Architecture and General Revit Questions
    Last Post: February 6th, 2018, 01:51 PM
  4. Global parameter for automatic sheet sorting?
    By PatrickGSR94 in forum Architecture and General Revit Questions
    Last Post: July 26th, 2017, 03:13 PM
  5. Sorting schedules using the mark parameter
    By Life Is Good in forum Architecture and General Revit Questions
    Last Post: January 23rd, 2013, 04:01 PM
