Results 1 to 4 of 4
Thread: Show existing contours along with proposed contours in view
  1.    #1
    Lurker
    February 11, 2019
    1
    04:01 AM
    I am struggling to create the attached graphic. Essentially, we need to show existing contours along with proposed contours. They each need to be distinguished graphically (one can be dashed and one can be solid). The existing contours need to stop where the proposed start (we don't want to show both systems overlapping). Thanks.
    Attached Thumbnails Attached Thumbnails Show existing contours along with proposed contours in view-revit-topo-question.jpg
  2.    #2
    Coeur d Alene, ID
    4,593
    08:01 PM
    Easiest method is to right click override the new surface to be solid lines.
    As for starting one and beginning another, you may need to demo some of the existing depending on what your new surface will be
  3.    #3
    Autodesk JeffH's Avatar
    December 13, 2010
    The Ivory Tower (Manchester NH)
    760
    11:01 PM
    I don't think there is any way to get the look you want from the contours without manually drawing them that way. You can get dashed and solid if you use the graded region tool, but it will not get rid of the line of the existing contour line where it changed. It will only show them as overlapping surfaces, each with their own set of contour lines. You could use that as a "base" to trace from, but to get it to automatically render like you are showing, pretty sure you are chasing a ghost on that one.
  4.    #4
    Mr. Revit OpEd
    2,782
    08:01 PM
    Overlay views on sheet...override views/elements to adjust what the toposurface looks like in each. The attached uses Graded Region to change the surface. The existing plan overrides the surface to be dashed. The proposed plan is set to Phase Filter Show Previous and New and overridden to be 60% transparent so I can see the existing contours.
    Attached Thumbnails Attached Thumbnails Show existing contours along with proposed contours in view-site.jpg
  1. Toposurface from DWG contours
    By kaneda in forum Architecture and General Revit Questions
    Last Post: November 30th, 2015, 05:27 PM
  2. Affichage des Contours de dalles
    By PAN21 in forum Forum Français
    Last Post: December 2nd, 2014, 10:11 PM
  3. Topography Contours
    By ayla_harvey in forum Architecture and General Revit Questions
    Last Post: August 29th, 2014, 12:54 PM
  4. Creating Walls That Follow Site Topography Contours in Revit
    By Simply Complex in forum Blog Feeds
    Last Post: July 3rd, 2012, 06:45 AM
  5. Create a slab from contours - 3D polylines
    By jh75 in forum Structure - General Questions
    Last Post: June 22nd, 2011, 03:23 AM
