Results 1 to 3 of 3
Thread: Exporting more layers to dwg
  1.    #1
    Lurker
    February 11, 2019
    1
    05:48 AM
    Hi everyone
    I have a really important question.and i would be really thankful if u could help me.
    I have to export layers from revit to dwg based on customer`s layer template. for example in his template there is more than 26 layers for just walls. but i can make only 6 independent and seperate layers for walls in revit. does anyone have an idea to solve my problem?
    Tnx
  2.    #2
    Mr. Revit OpEd
    2,782
    08:48 PM
    Revit is not merely a better way to make DWG files. It is a file translation from one format to another and Revit can't possibly anticipate or meet every permutation of standards people use in other software...even if Autodesk owns them both.
    At some point special requirements can only be met in the native file format with that software. The fact they have 26 layers doesn't automatically mean every layer is necessary or relevant. Discuss how important their requirements are and how not meeting them impacts their process. If it is significant enough it may be worth working in AutoCAD to meet their needs.
    Alternatively running a script or two in AutoCAD after exporting might reassign "walls" to the different layers they really want.
  3.    #3
    Member HansLammerts's Avatar
    April 22, 2011
    440
    05:48 AM
    Quote Originally Posted by Izamu View Post
    Hi everyone
    Tnx
    DWG is big fun with Revit ! :P
    Did you try the new tool?
    https://www.revitforum.org/architect...tml#post215238
  1. Different floor layers
    By Minotaur in forum Architecture and General Revit Questions
    Last Post: July 30th, 2015, 09:15 PM
  2. Exporting a model to DXF without exporting hidden elements
    By bshara in forum Third party Add-Ins, API and R&D
    Last Post: April 28th, 2014, 05:57 PM
  3. Linked CAD - Layers
    By domsib in forum Architecture and General Revit Questions
    Last Post: August 5th, 2013, 10:39 AM
  4. Layers
    By Silas in forum Architecture and General Revit Questions
    Last Post: May 7th, 2012, 01:52 PM
  5. see cut wall layers
    By Pickens in forum Architecture and General Revit Questions
    Last Post: February 13th, 2012, 11:09 PM
