Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Like Tree1Likes
Thread: Hey BIM Managers - How do you Deploy Revit Updates?
  1. #11
    Moderator cellophane's Avatar
    August 9, 2011
    Louisville, KY
    6,140
    08:34 PM
    I get the dialog box to actually start the install. Once that finishes it is fine.
  2. #12
    Moderator DaveP's Avatar
    January 10, 2011
    St Paul, MN
    2,980
    07:34 PM
    You mean the one asking for admin rights?
    I've noticed that once in a while, but it's real inconsistent.
    I start the batch file with "Run as admin", but maybe 1 out of 10 times, I get another UAC prompt asking (again) for admin rights.
    Haven't figured out what triggers that or why it even pops up.
  3. #13
    10,175
    07:34 PM
    I dont even get a dialogue box to start. Double click the shortcut, and off it goes. Just progress bar. When its done, it just disappears.
  4. #14
    August 9, 2011
    Louisville, KY
    6,140
    08:34 PM
    This one.
    Although it just occurred to me that they were never unblocked. Checking that now. Who's bright idea was it to require something like that?!
    Attached Thumbnails Attached Thumbnails Hey BIM Managers - How do you Deploy Revit Updates?-deploymentinstaller.png
  5. #15
    January 10, 2011
    St Paul, MN
    2,980
    07:34 PM
    There's a /passive switch and a /quiet one.
    Passive shows the progress bar & quiet is, umm, quiet.
    I like the passive because I run these manually & do several at a time. with the progress bar, you can gauge time remaining
  6. #16
    10,175
    07:34 PM
    This one.
    Unblocking makes those go away.
  7. #17
    August 9, 2011
    Louisville, KY
    6,140
    08:34 PM
  8. #18
    November 27, 2013
    33
    08:34 PM
    okay - i spent the past couple of days trying to get to the bottom of what was going wrong with my deployments... and i think the issue all started with me listening to my IT team.
    After scrapping everything they had told me about how to use PDQ Deploy, and doing my own independent research - I was able to put together PDQ Deploy packages that actually seem to work. I even cobbled together a powershell script that allows me to send Revit Updates out to everyone, but will only install the update on machines with the relevant version of Revit installed.
    switching to "/passive" instead of "/qb" was also helpful as i was finding the "/qb" switch caused it to uninstall revit updates on machines that already had them installed
  9. #19
    August 9, 2011
    Louisville, KY
    6,140
    08:34 PM
    Bill Debevc (https://bimthoughts.com/about/) did a class at RTC 2016 covering PDQ Deploy. You might see if you can get the handouts for it.
    cganiere likes this.
  1. Replies: 0
    Last Post: August 18th, 2015, 02:15 PM
  2. BIM / Revit Managers and firm size
    By mzabritski in forum Architecture and General Revit Questions
    Last Post: July 27th, 2015, 07:25 PM
  3. What technology do you use to deploy updates to Autodesk software in your company
    By Archman in forum Architecture and General Revit Questions
    Last Post: January 3rd, 2014, 10:04 PM
  4. 2014 Deploy
    Last Post: August 1st, 2013, 01:36 PM
  5. 2012 deploy issues
    By sdbrownaia in forum Architecture and General Revit Questions
    Last Post: June 21st, 2011, 12:14 AM
Tags for this Thread
