Results 1 to 1 of 1
Thread: Revit Window family:Can only select the 2nd void, when the 1st void has been deleted.
  1.    #1
    Junior Member theoryshaw's Avatar
    March 2, 2012
    Madison
    29
    09:32 PM
    The attached file has (2) voids in it. The only way I can select the 2nd void, is if I delete the 1st void. Curious why that is, and if there's a way to avoid having to do that.
    Attached Files Attached Files
  1. Window in wall with void
    By rcarr in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: June 4th, 2015, 02:38 PM
  2. Parametric Void Array Window
    By krcbickel in forum Architecture - Family Creation
    Last Post: June 12th, 2014, 02:13 PM
  3. How to void/cut a terrain/family
    By ngtan__thanh in forum Architecture and General Revit Questions
    Last Post: April 28th, 2014, 01:43 PM
  4. Void form not creating void.
    By mikey1073 in forum Architecture - Family Creation
    Last Post: December 6th, 2012, 03:13 PM
  5. Family Parameters : Void
    By Scott Deslippe in forum Architecture - Family Creation
    Last Post: May 5th, 2011, 06:12 PM
