Results 1 to 5 of 5
Thread: Schedules for Linked Revit Models
    Member MartinGT's Avatar
    August 17, 2011
    UK
    273
    09:30 AM
    I have got a site with several linked Revit Models. Some of the models have been copied around the site.
    I want to schedule the foundations and so far not having much luck! I have modelled the foundations in the Revit model at a level of -675mm from Floor Level which is at 0. I have then linked this model into a site model (the one I am trying to schedule from) which is set up to the correct Easting, Northings & Levels. I have put the models at the correct levels and copied them around where required.
    The schedule is taking the level at -675mm and not the level I have e.g 82.000m. I.e it's taking the model's level rather than the position within the site.
    Any ideas?
    9,895
    04:30 AM
    Unless you use shared coordinates to push the correct elevations back to the building (and use multiple Named Places for different locations on site) it's always going to be that way.
    It's doing exactly what it's supposed to do. It just isn't what you were hoping for.
    It's fixable, you have have to push coords for all the different site locations back to the linked model.
    August 17, 2011
    UK
    273
    09:30 AM
    Thanks. I did assume (which is always wrong!) that if I published the shared coordinates to a revit model inserted then copied it wouldn't work. Alas! It works fine!
    Thanks!
    August 17, 2011
    UK
    273
    09:30 AM
    I spoke a little too soon.
    I have several parameters in the link that I want as instance parameters. E.g - Plot Number etc. I have tried following this link to combine parameters however the combined parameter remains 'read only' and I cannot change it.
    Any ideas?
    August 17, 2011
    UK
    273
    09:30 AM
    I am now thinking that I will have to do this via multiple schedules and 'stack' them on the sheet.
  1. Revit OpEd: Selection Box and Linked Models
    Last Post: August 12th, 2016, 09:15 PM
  2. Do U Revit: Positioning of Linked Models – Part 1
    By Do U Revit in forum Blog Feeds
    Last Post: June 27th, 2013, 05:45 AM
  3. Do U Revit: Opening Linked Models for Editing
    Last Post: June 8th, 2013, 12:45 AM
  4. Revit Performance with 2 linked models
    By domsib in forum MEP - General
    Last Post: May 28th, 2013, 06:06 AM
  5. IFC Export and linked revit models
    By Miketmbt in forum Architecture and General Revit Questions
    Last Post: January 8th, 2011, 09:49 PM
