Page 1 of 2 12 LastLast
Results 1 to 10 of 12
Thread: Ansichten Symbol in der Detailansicht des Grundrisses
    January 2, 2019
    9
    09:53 PM
    Hallo, ich hab Probleme die Ansicthspfeile im Detail welches ich aus dem Grundriss gezogen habe Sichtbar zu machen, das Detail liegt auf einem Plan.
    ich habe den Grundriss bereits auf den plan gezogen, hier werden die ansichten dargestellt.
    danke schonmal!
    Attached Thumbnails Attached Thumbnails Ansichten Symbol in der Detailansicht des Grundrisses-ground-view.png   Ansichten Symbol in der Detailansicht des Grundrisses-detail-sheet.png
    June 21, 2012
    Tours, France
    937
    10:53 PM
    Hi, can you elaborate a little bit more (in english) please? what type of element is that?, which is its category? are you using filters? , Entshuldigung aber meine Deustch is kein gut!!
    January 2, 2019
    9
    09:53 PM
    ah sorry, i was mistaken^^. I made this view in the floorplan which has four directions activated. on my sheet i put a detail-window from the floorplan, which should show the arrows of the views so you understand where is the location of the views, but the views symbol which is shown on the floorplan didnt appear in the detail.
    i put the floorplan on the sheet too. it shows the view symbol, so it isnt the configuration of my sheet.
    maybe those icons arent shown in detail cut outs.
    or it is unvisible by scaling(but i tested it too in different scales)
    June 21, 2012
    Tours, France
    937
    10:53 PM
    Quote Originally Posted by kanzler View Post
    .... I made this view in the floorplan which has four directions activated. on my sheet i put a detail-window from the floorplan....
    is this the family you are looking to show in your plans?
    Can you upload that family?
    January 2, 2019
    9
    09:53 PM
    ive got new process in this case.
    it is the system family for views which is in the basic architecture-template
    BUT, i found out that the views i created are referenced on the detail i want to show on the sheet. And i think that is the probleme because the view arrows arent visible in my detail.
    June 21, 2012
    Tours, France
    937
    10:53 PM
    .....it is the system family for views which is in the basic architecture-template.....
    Ok I see, well without much more information I guess you need to check the Properties Palette with the view family selected and seek for "Hide at Scales coarser than" you may be able to see a value (Scale) at the right that value let you hide those symbols at scales which are not used or aren't important enough to show the view symbol, let us know if this works, regards
    January 2, 2019
    9
    09:53 PM
    here i tested the floorplan on the sheet the view marker is visible and in the Detail not -.-
    Attached Thumbnails Attached Thumbnails Ansichten Symbol in der Detailansicht des Grundrisses-ay-caramba.png
    January 2, 2019
    9
    09:53 PM
    Thank you for your help so far, but the hide by scale didnt work i tried it yesterday
    Attached Thumbnails Attached Thumbnails Ansichten Symbol in der Detailansicht des Grundrisses-didnt-worked.png
    June 21, 2012
    Tours, France
    937
    10:53 PM
    And What is the scale for the floor plan and for the detail?
    January 2, 2019
    9
    09:53 PM
    1:50 i think the Detail cutout is the problem
  1. Three little boxes symbol
    By misterjp in forum Architecture and General Revit Questions
    Last Post: September 14th, 2016, 09:47 PM
  2. Symbol/Symbol Offset for family
    By txelwood in forum MEP - Family Creation
    Last Post: April 18th, 2014, 09:28 PM
  3. Elec fixt symbol / placement ht / feed value to plan symbol label?
    By Fritz in forum Architecture - Family Creation
    Last Post: November 1st, 2013, 03:53 PM
  4. What does this symbol mean?
    By domsib in forum MEP - General
    Last Post: July 31st, 2013, 12:13 PM
  5. Replies: 0
    Last Post: March 6th, 2013, 11:16 PM
