Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: Ansichten Symbol in der Detailansicht des Grundrisses
  1. #11
    June 21, 2012
    Tours, France
    896
    11:38 AM
    well I've made a test and the only way I found to hide that detail is whit the "hide at scales coarser than", so if you select the arrow heads are you able to see if the scale is the same? see my picture please
    The first pic shows a similar detail, the second one show that the 3 selected arrowheads are hidden at one scale coarser than 1:50 the last one is hide at scale 1:500 maybe that is your issue, regards
    Attached Thumbnails Attached Thumbnails Ansichten Symbol in der Detailansicht des Grundrisses-scale-detail.jpg   Ansichten Symbol in der Detailansicht des Grundrisses-hide-2.jpg
  2. #12
    January 2, 2019
    9
    11:38 AM
    i opened a blank Project and made a Detail out of a floorplan and then made a view in the square of the Detail, first i got the same issue.
    but when i moved the view in the Project browser out of the ??? into views it worked.
    In my Project i made new Folder structure so i think its broken -.- i dont understand how to connect the Folders with properties
  1. Three little boxes symbol
    By misterjp in forum Architecture and General Revit Questions
    Last Post: September 14th, 2016, 09:47 PM
  2. Symbol/Symbol Offset for family
    By txelwood in forum MEP - Family Creation
    Last Post: April 18th, 2014, 09:28 PM
  3. Elec fixt symbol / placement ht / feed value to plan symbol label?
    By Fritz in forum Architecture - Family Creation
    Last Post: November 1st, 2013, 03:53 PM
  4. What does this symbol mean?
    By domsib in forum MEP - General
    Last Post: July 31st, 2013, 12:13 PM
  5. Replies: 0
    Last Post: March 6th, 2013, 11:16 PM
