Results 1 to 5 of 5
Thread: Casting Shadows on Topography and the views Level
  1.    #1
    Junior Member 411toaster's Avatar
    July 14, 2011
    Auckland, New Zealand
    34
    05:24 PM
    Hi all,
    I've got 3 views,
    1. A plan view based on roof lvl of one of the buildings. Shadows are correct
    2. A default 3d view showing shadows which are correct.
    3. A plan view based on a single level at RL00 called Datum (typically the only level in our master models that host the linked buildings)
    as you can see the shadows do not cast onto the topography as you would expect. Why is this?
    Attached Thumbnails Attached Thumbnails Casting Shadows on Topography and the views Level-shadow-query.jpg
  2.    #2
    February 23, 2018
    Port Elizabeth, South Africa
    46
    04:24 AM
    It's the cut plane level in that view that's cutting the buildings off at that height. Raise the cut plane level to above the buildings.
  3.    #3
    July 14, 2011
    34
    05:24 PM
    Hi Tim, I wish it was that. I haven't changed any settings apart from a PC restart and it's looking right now so it may have been a graphics card thing.
    cheers
  4.    #4
    Senior Member biff's Avatar
    June 13, 2011
    Australia
    829
    03:24 PM
    Check shadow settings in that view to ascertain you have shadows not checked on to land on a certain level. At the bottom right hand side of the sun settings window if i remember correctly.
  5.    #5
    July 14, 2011
    34
    05:24 PM
    Thanks Biff, checked that too. I mean unchecked it to not cast on any levels.
  1. Multiple level topography
    By Peter1979 in forum Architecture and General Revit Questions
    Last Post: August 18th, 2017, 02:02 PM
  2. Sun Settings and casting shadows
    By sgray05 in forum Architecture and General Revit Questions
    Last Post: May 26th, 2015, 05:03 PM
  3. Casting Shadow on elevation
    By leetecture in forum Architecture and General Revit Questions
    Last Post: January 19th, 2015, 06:26 PM
  4. Topography visibility in plan views
    By mona miller in forum Architecture and General Revit Questions
    Last Post: June 26th, 2014, 10:01 AM
  5. Different Level Heads for Different Views
    By GMcDowellJr in forum Architecture and General Revit Questions
    Last Post: November 9th, 2012, 04:38 PM
