Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
Thread: Width of Properties and Project Browser keeps changing
  1. #21
    Member PatrickGSR94's Avatar
    July 7, 2017
    Hernando, MS
    446
    02:11 PM
    Well I'm disappointed to report that 2020 continues to have this same issue. Docked dialog boxes jump around all over the place every time a project is opened (grows), or when 2 projects are open and one is closed (shrinks way down).
  2. #22
    December 13, 2010
    Ambleside, Lake District, UK
    941
    08:11 PM
    Yep, same here - right side docked Project Browser shrinks in width seemingly randomly after closing a project and opening another.
    Revit remembers the window width - closing a project with a shrunken right window width and shutting down Revit 2020, then restart and load another project the window width on the right of screen is as it should be.
    However loading the project that was saved when the shrunken window width occurred, it loads with that shrunken window width on the right of screen just as it was saved.
    Weird - and disappointing as Patrick says that it has not been sorted.
  3. #23
    Coeur d Alene, ID
    4,736
    12:11 PM
    My Properties and Project Browser windows are on my opposite screen and they get moved around so much that I never even notice on whether they are changing widths or not.
    Oh...I should mention I do not Maximize my primary Revit window. It is maximized manually and so far never changes. I was having weird graphic issues when it was maximized clicking the window toggle.
  4. #24
    December 13, 2010
    941
    08:11 PM
    That's an idea MPw - not maximising - I'll try that, thanks
  5. #25
    July 7, 2017
    Hernando, MS
    446
    02:11 PM
    I had issues with 2018 "bleeding" over onto my 2nd screen when it was fully maximized. However with 2019 that behavior appears to have been fixed.
  6. #26
    Coeur d Alene, ID
    4,736
    12:11 PM
    We skipped 2018...so had issues with 2017 and 2019. Still don't have 2020.
  7.    #27
    December 13, 2010
    941
    08:11 PM
    Just for the record I've tried working without maximising the main Revit 2019 window and it makes no difference to the width of the Project Browser window if docked on the right of the screen as it still shrinks when switching between projects at odd times.
    Just recently I found that dragging a Revit window onto another monitor had stopped working. The only change to my system has been allowing the latest Windows 10 updates to install and also updating the Nvidia Quadro and Geforce drivers to Enscape's latest recommendations (Geforce card just for rendering).
    It turned out that the dual displays were slightly misaligned when viewed in Nvidia Control Panel - never seen that before. Dragged them back into alignment and all working again.
  8.    #28
    July 10, 2015
    Boise, Idaho
    651
    01:11 PM
    At the Autodesk Revit 2020 webinar last week I asked about this issue. They said to send in a ticket and check your windows settings. I interpreted that as they have no idea blame somebody else
  1. Properties and Project Browser Frozen
    By Karalon10 in forum Architecture and General Revit Questions
    Last Post: January 22nd, 2019, 04:24 PM
  2. Properties Box and Project Browser Not Clickable
    By LKeyser in forum Architecture and General Revit Questions
    Last Post: July 21st, 2017, 10:27 AM
  3. Properties and Project Browser not showing entirely
    By helpless af in forum Architecture and General Revit Questions
    Last Post: December 1st, 2016, 04:35 AM
  4. Properties and Project Browser Locked together
    By JD003 in forum Architecture and General Revit Questions
    Last Post: July 4th, 2016, 12:27 PM
  5. missing project browser & properties icon
    By frelli in forum Architecture and General Revit Questions
    Last Post: June 19th, 2014, 04:06 PM
